Wer bremst verliert
JohnJL's Avatar
1971 Dash warning light?
I feel silly asking this very basic question and apparently I'm the first one since I cant find it in SEARCH...
What is this warning light on the dash? Mine stays on. Also, oil pressure barely reads when idling but acts as expected under acceleration, load and cruising.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-11-2007, 01:52 AM
cameron.arnott's Avatar
Hi John
Its your handbrake warning light!
Cheers mate!
'74 RS 3.0 Replica
Porsche 968 Clubsport SOLD
'70 911E Bahia Red SOLD
'71 911 S/T Replica 2.3 Twin plug BEAST SOLD
Old 10-11-2007, 02:10 AM
Wer bremst verliert
JohnJL's Avatar
Must have a bad switch or short maybe. The brake is definately off. Thanks.
Old 10-11-2007, 02:37 AM
1-6-2-4-3-5-1-6-2-4-3-...
pope's Avatar
Heh, I had the same two issues when I first got mine. My warning light was on only occasionally so I thought it had to do with the oil. It turns out that if the handbrake is up by only one notch, the light goes on.
My oil gauge also works like yours. Also, it goes up when the car gets warmer.
'70 911E Coupe, Webers 40IDA
Old 10-11-2007, 04:19 AM
Not sure about a 73 but I believe the light also is tied into the master cylinder brake switch circuit. You may have a faulty switch or poor connection at the MC if the E brake switch checks out.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 10-11-2007, 04:33 AM
304065's Avatar
John, that is the alternator warning lamp. The handbrake lamp is the TOP lamp which is also the brake warning lamp.
If it stays on continuously after startup, your battery is not charging. Search under my name for "blue wire" for a wealth of information about how to fix.
The "G" means "Generator" in German which means. . . er. . . "Generator" in English. A holdover from 356/912 days!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-11-2007, 05:47 AM
pope's Avatar
Absolutely right. The top one is the handbrake
Old 10-11-2007, 09:01 AM
Wer bremst verliert
JohnJL's Avatar
Hmmm. Perhaps I missed a wire when installing the new alternator. The battery is most definately charging...I've run the car for 1 hour for a time on joy rides with no problems and it starts without a problem.
Old 10-11-2007, 12:52 PM
304065's Avatar
Only way to tell is to measure the voltage at the battery.
It starts fine until it doesn't.
'81 R65
Old 10-11-2007, 01:48 PM
Zeke's Avatar
And the upper "hand brake" light will glow faintly if there is a problem in the m/c. Usually that's a grounding issue or a reset (on the side of the m/c) issue. But, if it come back on, there's a problem.
Old 10-11-2007, 02:03 PM
Wer bremst verliert
JohnJL's Avatar
John,
You mean check the voltage across the battery terminals (I get 12.57 all the time, new battery) or disconnect the ground to the battery while its running and check voltage or amperage across the ground strap to the battery neg terminal?
Old 10-11-2007, 03:50 PM
Whoops, sorry to lead you astray.......
Not enough time in the car lately!
'74 RS 3.0 Replica
Old 10-12-2007, 12:27 AM
304065's Avatar
John,
Thou shalt not ever disconnect the battery whilst the engine runneth lest ye fry thine electrial system, forsooth.
What I mean is, check the battery voltage with the engine running at the battery terminals. It should be at least 13.5v, if its 12.57, your alternator is not charging and the red light is a true indication that something is wrong. Which I believe it is.
'81 R65
Old 10-12-2007, 05:42 AM
