robotman's Avatar
banjo fitting on mc
Can i reuse the banjo fitting brass washer on the master cylinder or should i get a new one. I cant find on this site where to order it. Also does the banjo fiting go on the mc and then this washer and then the final brake line.
Old 07-08-2009, 08:26 AM
When you describe putting it together and say "this washer" ect lets try a pic and what yr. are you working on?
Most all banjo fittings use 2 crush / sealing washers replace them every time.
You should be able to match them up based on the ID & OD sizes, tey a motor cycle shop or local AP store, on the brakes DO NOT use aluminum sealing washers, go copper.
Regards
Old 06-03-2010, 05:57 AM
Mark S
Yes you can reuse run them over a piece of 300 + grit sand paper both sides it will take the ridges off nicely. Jerry is correct 2 washers per fitting. One first goes over bolt then install brake line then the other washer. In other words the washers sandwich the oil line.
Old 06-03-2010, 07:10 AM
if it seals, then yes it will work.
206 637 4071
Old 06-03-2010, 07:21 AM
