al lkosmal's Avatar
camshaft housing mystery????
I've always seen the 901 camshaft housings listed as 3 bearing types and the 930 camshaft housings listed as 4-bearing types. I recently received some camshafy housing assemblies with cam, rockers,heads, etc. in a parts lot.
Here's the mystery. I disassembled everything and here's the p/n's
camshaft housings are: 901.105.111.1R
cams: 930 105 146 7R & 8R (3.0?) 4-bearing
heads: 930.104.329.2R (3.0?) dated 7/77
These 901 housings are 4-bearing and mate with the early 3.0 cams.
Is this typical? Did the early SC's use 901 numbered housings.
Is it possible that these are early turbo or 3.0 carrera parts?
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 09-30-2007, 05:55 PM
Grady Clay's Avatar
Al,
Measure the cam bearing diameters.
Are the heads 2.7 stud spacing or 3.0 stud spacing?
What are the numbers on the ends of the cams?
With the '76 2.7 porsche changed to 4-bearing but maintained the smaller 47 mm diameter bearings.
With the '78 911SC the bearing diameter increased to larger diameter.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 09-30-2007, 06:42 PM
al lkosmal's Avatar
Grady,
3.0 stud spacing.
Numbers at end of cams: 930 74708 and 74806 (could be in error..hard to read)
bearings measured at 49mm
regards,
al
RGruppe #669
Old 10-11-2007, 06:23 AM
al lkosmal's Avatar
bump
RGruppe #669
Old 10-14-2007, 08:50 AM
