Checking torque on cylinder heads
I've got my 2.7L engine out right now and I was wondering if it's a good idea to check the torque on the cylinder heads. Am I at risk of breaking a head stud? The engine runs great, only has 50k miles, and I'm not having any problems with it.
thanks
Old 09-18-2013, 01:46 PM
You wont break a head stud, thats an aluminum case problem. The torque will pull the magnesium threads so you will have to case save insert and install dilivar after a complete disassembly.
Bruce
Old 09-18-2013, 01:58 PM
ROW '78 911 Targa
timmy2's Avatar
Just check to make sure they aren't loose and leave them alone...
Old 09-18-2013, 02:15 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Bruce
Bruce,
Are you saying not to check the torque?
It's a good question but I am not sure of the answer.
1981 911SC Targa
Old 09-18-2013, 02:17 PM
Great. They're not loose and I'm leaving them alone. The alternative doesn't sound nice.
thanks guys
Old 09-18-2013, 02:18 PM
Functionista
manbridge 74's Avatar
You chose.... wisely.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 09-18-2013, 02:36 PM
ROW '78 911 Targa
timmy2's Avatar
Yeah! The real fun starts when a nut and a piece of the stud falls on the ground for the aluminum case engines. Or when the nuts just keep tightening on the magnesium ones...
Old 09-18-2013, 03:13 PM
Bob, I wouldnt take them to spec, as long as they arent falling off. Youre dealing with a sure fired rebuild on a 2.7 and that isnt cheap....
Bruce
Old 09-18-2013, 03:24 PM
Initial break-away torque is much higher than the torque spec. The most accurate torque readings are obtained as the threaded fastener rotates.
Thus, to re-torque accurately, each head stud nut should be first loosened slightly, then brought up to the specified torque as it rotates.
Check for loose fasteners by applying a fraction of the specified torque (YMMV). If it's loose, you'll feel it move.
Sherwood
Old 09-18-2013, 03:48 PM
Bob Kontak's Avatar
Got you. That is a lot of risk.
1981 911SC Targa
Old 09-19-2013, 05:18 AM
