Don't do what I did (non PPI story).
After selling my solid SC, I decided I need a longhood. Came across a nice 70T for a good price from a broker advertised as having some minor rust and a rebuilt engine, so I pulled the trigger.
The car shows up as advertised but with a thumping idle. As I have a business trip and an out of country trip pressing me I park the car, figuring it just needs a carb adjustment or a tune up. No such luck, the car is at Eurocar Werks today getting a compression test. I am bracing for the worst.
Anyway don't kick me when I am down. My stupidity, just thought I'd share.
Old 10-15-2007, 11:49 AM
durn for'ner
livi's Avatar
I am sympathetic with you worrying, but you might get lucky. I did.
No matter what, that is one of the most gorgeous (I know it is a sissy term) cars I have ever seen. The general design of the pre 74 cars are beyond approach by any other vehicle ever done IMO. A nice one in that beautiful color (what´s it called ?) is simply lovely.
Good luck!!
Markus
Resident Fluffer
Carrera '85
Old 10-15-2007, 11:54 AM
SCWDP911's Avatar
Sorry to hear of your potential troubles, but it sure is a beauty... Good luck with it.
Shane
- 1984 928S
Old 10-15-2007, 12:04 PM
Thanks Markus for the encouragement.
The color is non-Porsche metallic blue done by the previous owner. It is very close to current Mini Cooper Indy Blue. I know this because I walked around with a small color chip that came off the rear valence and every time I saw a blue car I held the chip up to it. It made for some interesting parking lot conversations. Previously the car was Guards Red.
Ulrich
Old 10-15-2007, 12:05 PM
Slumlord
Porsche_monkey's Avatar
Any chance of a warranty? Otherwise, if worse comes to worse, maybe the low price will justify a rebuild?
Old 10-15-2007, 12:13 PM
Early_S_Man's Avatar
Porsche Crest
Just what IS a 'thumping' idle???
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-15-2007, 12:27 PM
911 addict
mtbguy's Avatar
Live in Houston/No PPI, any chance you bought it from Victory?
I am not knocking you when you are down, because I bought one from him them that had "issues". Hang in there- I'm sure that there are many of us on this board that will/wont admit to our mistakes.
Its a really nice looking car!
1987 Carrera Cab
Toyota Landcruiser
500SL
Old 10-15-2007, 12:34 PM
Designer King
Paulporsche's Avatar
I like that color. Who cares if it is for a Mini?
Are you referring to a "lumpy" idle? Could be just a jetting, a carb or idle setting, or maybe timing.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-15-2007, 12:39 PM
No didn't buy from them, I know of their reputation. At least I would have been able to drive the car prior to purchase since I am in Houston as well.
Ulrich
Old 10-15-2007, 12:40 PM
Slumlord
I had a Honda beside me at the traffic light with a 'thumping idle' this morning. It's a combination of hip-hop and too much bass.
Very annoying.
Old 10-15-2007, 12:46 PM
There you are giving me hope again when I had already braced myself for a rebuild. How cruel
How to distinguish between a lumpy and thumpy idle? The car shakes slightly when idling and is blowing white smoke (not unusual for 911 that's been sitting), my mechanic came up with the phrase.
Ulrich
Old 10-15-2007, 12:57 PM
450knotOffice's Avatar
White smoke? Does it dissipate or does it fill the air and drift off with the wind? Blue smoke (oil) would indicate a problem. White is usually steam that would be due to moisture in the engine being burned off.
How does it run otherwise?
GORGEOUS car, btw!!
Old 10-15-2007, 01:18 PM
Deschodt's Avatar
Ah, that's nothing... I did a pretend PPI (seller: another potential buyer just had it checked, let me send you the ppi he got. Me: Uh, ok)
Mine turned out to be made of 2 cars, a 72 nose, a 73.5T rear end. Costlier than your issue, which may still turn out ok !
Old 10-15-2007, 01:28 PM
Idles like a dragster at the starting line and shakes slightly, white smoke does diminish after a few minutes but does not go away completely.
Ulrich
Old 10-15-2007, 01:30 PM
I see you're in Houston.
I hate to even bring this up, but is there any possibility that the car was flooded during Katrina? Is it possible that water got into the crankcase?
Old 10-15-2007, 01:45 PM
No thank goodness. Title shows previous owner at that time was in Colorado.
Ulrich
Old 10-15-2007, 01:50 PM
Warren Hall Student
Bobboloo's Avatar
From what you've written there's nothing that leads me to assume the car isn't what was advertised.
"Rebuilt" means different things to different people that's why paperwork is necessary to determine what "rebuilt" means. To some people a valve job means the motor was rebuilt. Most people refer to this as a top end rebuild. To others rebuilt means the longblock is rebuilt. This is the most common use and doesn't involve any of the ancillaries (dizzy, alternator, induction, exhaust etc.) To others still it means the whole engine including ancillaries. This is rarely the case.
A lumpy idle caused by an induction or electrical problem wouldn't be solved by a longblock rebuild so don't assume that you were taken in regards to the rebuild statement. You first need to diagnose the problem and take it from there.
Rarely does buying a 37 year car go off without a hitch unless you are paying the big bucks for a completely sorted car.
Relax. Take a breath and then proceed.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 10-15-2007, 02:09 PM
Dan in Pasadena's Avatar
Originally Posted by Bobboloo View Post
.... Rarely does buying a 37 year car go off without a hitch unless you are paying the big bucks for a completely sorted car.
Bob is right. Try to remember it is approaching FOUR decades old before you jump off the roof!
"Bumpy" or "lumpy" strikes me like it COULD be a vacuum leak. For your sake I hope it is. Try the WD-40 around likely leak locations while idling and see if the idle smooths out even if only mementarily.
Also, I would suggest you not compound your troubles by taking the first mecahnic's word that it must be rebuilt - if indeed that comes back as his opinion. Not saying he's not honest, but there are plenty of them that are not or are just mistaken. Get a few opinions and post here with as many specifics as you can before opting for such an expensive fix.
As with everyone else, that is a very pretty car. Easy to see how your heart overruled your head. Mine did!
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 10-15-2007, 02:46 PM
AutoBahned
RWebb's Avatar
The worst case is that you paid too much for a beautiful car in a great color that is one of the ultimate Porsche classics (along with 356 & 550). That isn't too horrible and will get less so as you put years and miles on the car.
The color is fabulous - I also took a red early car to a nice blue.
It may be fairly minor. If not, then you may be able to challenge the "rebuilt motor" part of the contract in court. Or the threat might be enough to convince the seller to help you out a bit.
Meanwhile, contact the PO in Colo. and ask how the car was when he sold it.
I hope a third party is looking at the motor - not the seller or seller's agent.
Old 10-15-2007, 02:48 PM
Booney1golf's Avatar
Get a 2nd opinion regardless f what the current shop tells you. Ask me how I know. I ended up saving alot of money and the car has never run better.
Just my 2 cents!!!
Booney1golf
85 911 Carrera Targa - And I use to think golf was addicting
Old 10-15-2007, 02:50 PM
