Author of "101 Projects"
Need help identifying a part that fell out of my 959 door...
I know I've seen this before, but I can't tell where it comes from. Tom Woodford thinks it's part of the latch mechanism, and possibly a remnant from an old broken mechanism that was replaced a long time ago. But, I can't really see in there too well to tell where this goes, or where it's supposed to go, and I don't have any spare doors to look at, or a really good photo either.
Anyone have any additional information? The part is metal - looks like aluminum to me. It looks like it should be pressed onto something else - there are no screw holes in it. I think it might be related (as Tom said) to the lock key / opening / closing mechanism. I'm at home right now, and can't look at the car either. PET isn't really helpful either: http://www.pelicanparts.com/PartsLookup/HTML/E_959_KATALOG/804-05-Frame3.htm I think it's part of item number 1 on the diagram above. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Ooops, forgot the photo...
![]() ![]() -Wayne
Oh, and that's just a random post-it note, it's not a mirror cap.
Thanks, Wayne
Friend of Warren
Wayne that is part of the window regulator. Holds the wind up spring in place. I posted a similar picture and posting probably 2-3 years ago. If your window still works then someone already replaced the part and left the broken piece in the bottom of the door.
Here is my thread: What is this Part????
Kurt V No more Porsches, but a revolving number of motorcycles. Last edited by Rot 911; 10-16-2007 at 12:05 PM.. |
Heh. I once pulled something like that out of my 356.
Turned out to be a window piece.
1987 535is, 1966 GTV, 2015 F-Type R, 2013 991 C2, 2011 E550c, 2007 997 C2S, 1987 911, 1958 356 1600s, 1956 356 1600s |
What they said.......window regulator part for the rewind/wind-up spring
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
Ova Day
Yep, I found one in my door too. I heard it fall out when lowering the window. It sounded like somebody had dropped a rock inside the door. My window still goes up and the part has not been replaced. The inner end of the spring is normally held by this part. I used a mirror to look at the location and found the spring was still in place and doing its job. It is wedged in a tight place. It might pop loose at some point and make a nasty noise but for now it still functions. You would probably need to remove and rebuild/replace the regulator to fix it correctly. The mounting area on yours is distorted just like mine.
Considering your car and resources, I don't recommend waiting for it to pop loose. It could damage an unobtainium door panel. It is project #102!
88 Triple Black 911 Carrera Cab, ex Garage Queen 05 BMW E46 M3 21 Tesla Model 3 LR 08 BMW 328xi 15 Ford F150 Last edited by msterling; 10-16-2007 at 12:16 PM.. |
Cool. I thought it might have been a window regulator piece, but I wasn't sure. Didn't Weltmeister make an upgraded piece to replace this? Seems like it should be tapped and screwed in here - looks like the Germans cheaped out on this one...
Thanks guys, this does help a lot... -Wayne
Seems like a bad design to me. I also seem to remember myself saying something like this many years ago. If this piece is missing, I think I will take out the regulator, and tap this piece, and screw it in permanently, instead of this "press-fit" stuff... -Wayne
Senior Member
I replaced those things every six months on my 959. Eventually replaced it with the GM equivalent.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
AutoBahned
not really press-fit -- they (at least by '73) are 'peened' in -- still lousy
maybe this will stimulate Pelican to carry an upgrade part... what is the GM equivalent?? |
Actually, Weltmeister makes an upgrade part, I will make sure that we put it in the catalog. I remember seeing this in a competitor's catalog 10 years ago, before I started Pelican...
-Wayne
19 years and 17k posts...
Wayne,
You've only had the 959 a few weeks and you've already broken it!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Band.
I too, am in the "whatzit broken window regulator piece" club. Welcome!!!!!
Many enter, but few leave this club, it seems.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Now I have something in common with a 959.
Sherwood |
i've fixed lots of them with washer and a bolt. drill and tap of course. it would be nice to have a reasonably priced source for these. i have a lot of regulators that need to be fixed. as long as the piece hasn't split, it can be reinstalled. there are long and short ones and some have the slot on the same plane as the flat sides of the opposite end and some are 90° to it.
FWIW, the Weltmeister piece must weigh 2-3 times the Porsche piece. At least it felt that way when I fixed my broken regulator.
Neil '73 911S targa |
yeah, it's steel, not pot metal. mo betteh.
I managed to stuff my head in there tonight, and saw that there appears to be an intact pivot piece in regulator, so I suspect this is from a previous regulator failure. Lots of bad things happening in this door, I will post on another thread...
-Wayne
Just saw this note. Porsche does not sell just the pivot pin. They want to sell you an entire assembly. You can see the Pivot Pins listed on the P****** P**** Catalog. Your folks at the order desk are able to get them once you give them the competitor's catalog number at the same price. They come in 4 "flavors". The P******* P**** Part numbers are 910391, 910392, 910393, and 910394. It would be nice to see it listed here directly. This issue comes up on this BBS about once a year.
