Friend of Warren
What is this Part????
I had a rattle on the passenger side door of my '86 Carrera. Pulled the door panel off and found this laying inside. I have power windows. Is it part of the regulator? The window goes up and down just fine.
Gratuitous early evening car picture:
Kurt V
Old 11-10-2004, 06:06 PM
Kurt, I just had the same thing happen on my drivers side several weeks ago, and posted this thread:
Can someone identify this window/door part?
That thread will take you to another... bottom line...if your window is working OK, it has already been fixed...hope this helps.
Old 11-10-2004, 06:12 PM
That part holds the spirally wound spring on the window regulator assembly. All window regulators in 911s use them- manual and electric. if your window works fine, perhaps this was from an old repair where the part was left in the door. if not, i think our host has them- measure the height since there are different models. if not, Performance Products carries them
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 11-10-2004, 06:16 PM
Friend of Warren
Thanks for the quick responses guys!!!!! Hard to believe 3 of us had the same problem within 30 days. Anyway, I am sure this part has just come off as I had the door panel off a couple of months ago and vacummed out the bottom of the door and it wasn't there then. Is it possible the spring just hasn't popped off yet? How is a new one installed?
Kurt V
Old 11-10-2004, 06:43 PM
jstgermaine's Avatar
...and you don't even have....nah, nevermind.
'99 996~LSD~VE Wheels~H&R Cup Kit~Aero~Recaro~X51~M&K~GT3 Roll Bar
'77 911 ~ very modern running gear ~
Gruppe B...the Midwest motorsports playground
Old 11-10-2004, 06:46 PM
Virginia Rocks!
VaSteve's Avatar
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 11-10-2004, 06:48 PM
Friend of Warren
You bastards!
Kurt V
Old 11-10-2004, 06:51 PM
The rectangular end fit's in a rectangular hole in the window regulator arm. You can put it back in and smash the back of it like a rivet.
It holds the outer tab on the coil spring. When it's missing the tab get's caught on something else. That's why uyou probably didn't notice anything different.
Give it a try before buying a new regulator.
Also check the plastic window stops that are on the regulator arms. They sometimes break and or crack.I've seen them made with either hard white plastic and hard black rubber. Don't know when they changed, but I think the black ones will last longer.
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 11-10-2004, 10:09 PM
Friend of Warren
Bill, thanks for the additional information!
Kurt V
Old 11-11-2004, 06:18 AM
Send a message via AIM to Oldporsche
Cool
This is another piece of Porsche exceptional engineering.
BTW, this one is a piece of the original pivot for the window regulator.
They are made of Zinc! There are two versions of them depending upon the style and year of window regulator. One version has the flats parallel with the slot for the spring, the other at right angles. Replacing them in your window regulators will often improve the ease of making the window go up and down.
I have remanufactured them from bronze, hard aluminum, and steel. All of them worked better that what was in there.
Goodluck,
David Duffield
Old 11-11-2004, 08:23 AM
