Swaybar bushings, help!
Hello,
I'm not a great mechanic, of course, and I have a probem that seems easy but it's getting me mad.
I bought 2 swaybar bushings part #901-343-782-00-M260, it's the bushing that joins the swaybar drop link to the car. I mounted them into the drop links and now I don't know how to push them hard enough to make them enter into the pin on the car.
Can you help or give me any clues how to push it to enter in the pin? Any special tools.
I forgot, the car is a 1974 911 Carrera
Thanks,
Josep
1967 911 Soft Window targa
1969 911S 2.0 targa
1977 911S Sunroof coupe
1979 911 Turbo 3.3
Old 10-18-2007, 11:11 PM
Are these the hard plastic type or rubber bushings? I have a later car with a different style bushing, but I seem to recall that the hard bushings need to be heated up in hot water to make them pliable enough to put on.
Tony G
2000 Boxster S
Old 10-19-2007, 03:44 AM
Hello,
they are hard plastic in white, now they are inside the drop link, how can I do?
Josep
1969 911S 2.0 targa
1979 911 Turbo 3.3
Old 10-19-2007, 04:18 AM
you might try heating them up with a blow dryer or a heat gun.
Tony G
2000 Boxster S
Old 10-19-2007, 04:43 AM
with car down on ground
I wack mine cold with a piece of 2' 2x4 extension and a baby sledge from on the side of the car. I also grease them first. Dirt stays outside the tight bushing.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-19-2007, 06:33 AM
Lube the ball socket, then use a long water pipe, pry bar or equivalent. Find a convenient area on the chassis/suspension close to the ball to anchor the end of the pipe, then add leverage with the pipe to force the drop link assembly toward the ball. It should pop right in. It's easier if you have enough swing room under a car (i.e. car on lift, not on jack stands). It's also easier if the chassis is lifted with the suspension at ride height rather than hanging at full droop, as it would be on a muffler or alignment rack.
As Ron suggests, a 2x4 and BFH also works, but cunning persuasion is always better than beating it to submission.
Sherwood
Old 10-19-2007, 06:04 PM
Sherwood
Good suggestion,...
I use a monstrous pair of Snap-On slip-joint pliers and its very easy.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-19-2007, 08:03 PM
Hello,
thanks all. I tried the heat and didn't work. At last I did it in a more "original" way.
I used an old seat belt tied to a strong cord with the bushing aligned to the pin, then the cord linked to a car. True, it worked, it was not an easy task, strong force needed.
Josep
1969 911S 2.0 targa
1979 911 Turbo 3.3
Old 10-20-2007, 12:34 AM
Originally Posted by oldautoradio View Post
Hello,
Josep
Joseph,
I'm trying to picture this. You used another car to install the drop link ball and socket? Did it have a towing package? Whatever works I suppose.
Sherwood
Old 10-20-2007, 01:33 AM
Hi,
the belt carefully fitted with the drop link and ball socket correctly aligned. A cord pulling the belt so it will force the drop link to enter the socket. As we need strong force, I tied the cord to the car`s towing point and then started the other car pulling the cord making the bushing enter without problems.
Of course the 911 was inmobilised with the parking brake and a couple of wood cubes at the rear of the wood.
Josep
1969 911S 2.0 targa
1979 911 Turbo 3.3
Old 10-20-2007, 03:12 AM
Diss Member
Quicksilver's Avatar
Still trying to visualize it.
I want video!!!
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 10-20-2007, 04:38 AM
Will send a photo later.
1969 911S 2.0 targa
1979 911 Turbo 3.3
Old 10-20-2007, 05:48 AM
3.2 CAB's Avatar
The easiest way I found was to use a large "C" clamp, just tighten it up till the bushing pops onto the ball stud.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 10-20-2007, 09:51 AM
kilodawg's Avatar
Just completed this minor project this morning on the '73. It took me longer to figure out the best way to get the bushings into the drop link than it did to get the drop link and bushing pressed onto the peg.
In hindsight though it's real easy and having done it once I think I could do it again in under 45 minutes from getting the jacks out to clean up complete.
I used a pair of pliers to get the bushing into the drop link and then an 8" C clamp to press the drop link onto the peg. I found it very helpful to put a thin piece of wood between the back of the banana arm and the C clamp to keep it from slipping.
Again not being mechanically inclined by birth I found this to be another confidence builder...
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 01-06-2008, 09:00 AM
Chuck Moreland's Avatar
Probably as many ways to do it as there are people doing the job.
But go easy on the grease. Too much in the socket creates a hydrolock condition that keeps it from popping on.
Chuck Moreland - elephantracing.com - vonnen.com
Old 01-06-2008, 09:27 AM
Bland
unclebilly's Avatar
Hello,
Josep
This system works quite well. If you rig it up with some extra fishing line and some pullies you can also pul out teeth at the same time. you sit in the car on the passenger side and have someone slam the driver's door... works like a charm!
Old 01-06-2008, 09:57 AM
