2002 996 C4S
jcsjcs's Avatar
Missed Shift - When do you worry?
I had a blast over the weekend exploring the back roads of Eastern PA. '84 911 Targa - with the top off. The leaves are just changing, the roads were dry and curvy, and this was my first time with the car outside of New York City!
I did have one "Missed Shift" from 5th to 2nd - ugh. Looked like the tach went to about 7000 (that is just an after-image in my head for some reason - not necessarily true.) I reacted very quickly and punched the clutch and found the right gear. No obvious after effects - the car performed fine the rest of the weekend.
Should I worry?
jcsjcs
Have: '02 996 C4S
Had: '87 944, '84 911 Carrera Targa
Old 10-22-2007, 01:02 PM
Oh Haha's Avatar
You should be OK. 7000 isn't really that high for these engines. If you don't hear any funny noises don't worry about it. If you spun it up to 8000 I would worry but you should have an RPM limiter so you don't do this.
Pacific Blue
Wayne
Old 10-22-2007, 01:08 PM
The rev limiter will not help you if you blow a shift,it only cuts spark but does not stop your engine from over revs any way mechanically.
Brent Lineker
1975 911S
weber conversion.
Old 10-22-2007, 01:13 PM
Oh Haha's Avatar
Brent,
Yup but I was thinking that he might feel he had free reign to run it up to 8000. Guess I wasn;t looking at what I was typing. duh.
Pacific Blue
Wayne
Old 10-22-2007, 01:16 PM
GFCC
Jeff's Avatar
Does it idle OK?
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 10-22-2007, 01:31 PM
2002 996 C4S
jcsjcs's Avatar
Idle is the same as always (at least since I have had the car - about 1 month.) Stays stable within about 50 RPM or so.
What's the solution to this problem (other than being more careful)? Shifting from 5th to 4th feels like a bit of a potshot - too far to the right and you get some reverse gear grind, too far left and you blow your engine.
Does a Gate Shifter solve this problem?
jcsjcs
Have: '02 996 C4S
Old 10-22-2007, 03:05 PM
get a wevo shifter
Old 10-22-2007, 03:08 PM
GFCC
Jeff's Avatar
Sounds like you dodged a bullet.
Wevo is a great shifter. You can also look at Rennshift. They both have centering springs (will put the shifter in between 3-4 in the neutral gate) which should alleviate hunting for the correct gear.
Jeff
Old 10-22-2007, 03:21 PM
emac's Avatar
Got lucky-- I did the same thing and had to replace the clutch. Needed it anyway.
Ernie 81 SC
Old 10-22-2007, 03:24 PM
Platinum Member
dad911's Avatar
if the shifting is vague, inspect/change the bushings.
$6500 If you bend the valves..... there, bet you shift a little slower now......
Old 10-22-2007, 04:25 PM
RPM limiter won't help a bit with a missed shift.
Old 10-23-2007, 08:45 AM
304065's Avatar
Run a compression AND leakdown test and report the findings.
It is far better to tear down the engine to replace the rod bolts and any bent valves than to break a rod and blow a window you can put your fist through in the side of the engine case.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-23-2007, 09:15 AM
2002 996 C4S
jcsjcs's Avatar
How difficult to run compression and leak down at home? What do I need to do it myself?
While I am concerned about the missed shift - I have absolutely no symptoms that anything is wrong or different - no strange noises at idle, normal idle, car is running as always, etc. I expect that the blip in the 7k range did not do any damage but are there any other things I should look out for to see if any damage was done? While I agree I don't want to "blow a window in my engine", I also don't want to overreact with nothing to go on other than the story itself, i.e. no symptoms of a problem.
Thanks for the input!
jcsjcs
Have: '02 996 C4S
Old 10-24-2007, 06:06 AM
304065's Avatar
You need a decent air compressor and a leakdown tester. A special adapter for 911 engines that fits into the spark plug hole with a quick-disconnect fitting is nice to have.
Or any local shop can help, it's about a 1 hour task to do it right. Where are you in the City, I can recommend somebody to take it to if you don't want to invest in the equipment.
'81 R65
Old 10-24-2007, 06:54 AM
2002 996 C4S
jcsjcs's Avatar
I live in Brooklyn, but have no problem traveling to Long Island or the other boroughs.
jcsjcs
Have: '02 996 C4S
Old 10-24-2007, 07:03 AM
You can tell alot just by turning over the engine by hand. Turn it with a wrench on the fan nut while pushing on the side of the fan belt to keep it from slipping. You should have the same compression feel on all 6 cylinders. If you feel some of them are significantly easier to turn through TDC then you may need to investigate with a leak down test. You can also hear the air hissing out when you do this. It should sound the same on all 6 cylinders and should come from the case of the engine not the intake or exhaust.
-Andy
Old 10-24-2007, 04:14 PM
