AutoBahned
RWebb's Avatar
Jon's tub sounds like a good one if you choose that path.
Keith wrote "start with a 964."
- The 964 tub is a LOT stiffer than the true 911 tubs. A big bonus is that the tub itself (stripped of everything else) is just 40 lbs. or so heavier. So you get a lot for a low wt. penalty. The 964 will likely cost more tho and will entail more work to convert, incl. the interior.
Keith -- if you are converting a 964 to an early car look low wt. racer, could you start a thread and post pics and details? We don't have much on that process documented. Pdoc's is the only one I recall.
Old 10-26-2007, 12:15 PM
Friends of Warren
911teo's Avatar
here you go
zuffenhaus C2 to '72 RSR project...
Matteo
Warren RIP
www.impactbumpers.co.uk
Old 10-26-2007, 12:46 PM
