FinallyGotOne's Avatar
Porsche Crest Heres pix, thought I had black boge but no. please confirm proper insert '79 911sc
Thought they were black, but they are painted red, by I think previous owner. Originally appear to be green. heres the pix, looks like it has the retaining pin every one discusses. please expert opinion on proper insert. Not sport.
I bought these today: Bilstein F4-P36-0112-H0 will they work?
Old 10-25-2007, 03:53 PM
Hell Belcho
Nostril Cheese's Avatar
Bilsteins
drive out the pin and throw the new ones in
Old 10-25-2007, 04:01 PM
OK. heres the answer to my own question. Per the guy at Bilstein. I need to use F4-R36-5001-HO- Not sport since I am looking for a bit of comfort on these terrible colorado roads!
Autozone can get them from Bilstein in couple days.
Old 10-25-2007, 04:29 PM
sports are not a whole lot firmer than HDs.
206 637 4071
Old 10-26-2007, 08:32 AM
Somatic Negative Optimist
Gunter's Avatar
Originally Posted by Nostril Cheese View Post
Bilsteins
He is not replacing the ball joint, so, no need to drive out the wedge pin.
There can be oil inside the strut housing.
Not sure if that is emptied out?
JW suggestion about the exchange sounds great; no effect on the alignment as long as the 3 Allen bolts are left alone.
Some sort of strut nut wrench is needed and the torque is given as 87 + 14 ft-lbs for the insert.
To me that would be a pre-torque of 87 and then an additional 14 ft-lbs.??
The top mounting nut M14 needs a torque of 59 ft-lbs.
All this info is from the Bentley SC Repair Manual.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-26-2007, 09:01 AM
Hell Belcho
I dont know how many Billies you've changed out, but every time I've done it, you drive out the roll pin with a punch. To do the ball joint you need a special socket on the underside of the a-arm.
Agree that if you dont touch the allens on the top, no alignment is needed.
Old 10-26-2007, 10:35 AM
Hell Belcho
This is the pin im talking about
Old 10-26-2007, 10:38 AM
Yeah, on a Bilstein housing you've got to remove the pin to get the insert out. If your insert comes out without removing the pin, you've got problems.
There shouldn't be any oil in a Bilstein housing. A Boge housing would be full of oil though.
Old 10-26-2007, 12:10 PM
Gunter's Avatar
Thanks for clarifying between roll pin and wedge pin.
Soaking the roll pin with penetrating oil will help.
The Bentley must be referring to Boge inserts.
Cheers.
Old 10-27-2007, 08:31 AM
