Andi1's Avatar
Send a message via AIM to Andi1
Newbie observation question...
My 3.0 motor does not have this! What is it? I know the other thing is A/C....
uno '89 BMW 325is-------'94 BMW Touring----(Daily Drivers)----
1976 911 Carrera 3.0 signature edition (euro)---964 body
1976 912E ----------(Weekend Warriors) --1992 Volvo wagon--(SPARE transport)
Old 10-22-2007, 03:12 AM
Ferdinand Magazine
johndglynn's Avatar
That is an air pump, you don't want one.
What is a signature edition Carrera 3.0? Tell me more...
Sheriff at www.impactbumpers.com
Brand support at classicretrofit.com/tuthillporsche.com
1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles
Old 10-22-2007, 03:40 AM
Is it any big deal to dispense with it? Any down side?
Old 10-22-2007, 05:05 AM
Only down side is passing emission check, if your state requires it. It's part of the system that will fail you on the visual if it's not there
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 10-22-2007, 05:13 AM
Aside from the air pump, I'd check with this group and see if it's possible to remove that 5 blade fan and replace it with an 11 blade fan. Better cooling, especially during those long hot Texas days.
Old 10-22-2007, 05:18 AM
+1!
L.J.
Old 10-22-2007, 05:20 AM
One delightful aspect of dwelling in a rural state is not only no emissions check, a few years ago they cancelled their safety stickers.
I would like to remove mine, but am reticent to do so as it is running SOOOO well now.
Surely you don't simply "unhook"??
Old 10-22-2007, 07:17 AM
AutoBahned
RWebb's Avatar
No you shouldn't just unhook it. If removed, the engine needs to be tuned differently, and maybe different spark plugs would be used.
Old 10-22-2007, 11:10 AM
I'll wait till it goes belly-up.
Thanx
Old 10-22-2007, 11:24 AM
Ferdinand Magazine
johndglynn's Avatar
I would lose it sooner than that, might never break and if you don't do smog you don't need it. The only complication with them is that the injectors under the car can sometimes pull threads when you screw them out if they are seized, so if you are not using heat to aid the process, the best way usually is to junk the pump and then cut the lines near the injectors, sealing with a blob of weld.
I would do a search for further opinion on plugs and lose that thing, your car will thank you for it, it makes lots of jobs much easier and the engine bay looks better without it. Then move on to the heat backdate
Old 10-22-2007, 11:40 AM
Less brakes, more gas!
euro911sc's Avatar
Ripped mine out and plugged up the holes... no sweat no worries...
-michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 10-22-2007, 12:09 PM
""Then move on to the heat backdate ""
uhhhhhhh..wanna touch a bit on that?
Old 10-22-2007, 07:02 PM
Andi,
I am in Houston as well. I am sure you know your car is exempt from TX emission testing so you won't need the smog pump. I removed it from my old 78SC, but taking out the plumbing "spider" under the car was not easy. There are special plugs from Weltmeister that close the injector holes.
Just starting on my 70T project car.
Ulrich
Old 10-22-2007, 07:13 PM
Ferdinand Magazine
johndglynn's Avatar
heat backdate - wanna touch a bit on that?
Do a search for this as is off topic and has been covered many times. Basically you are losing the electric heater blower and convoluted pipework from the engine compartment and taking your cabin heat direct from the engine fan. It is a very sweet mod, easy to do and tidies everything up a treat.
Old 10-23-2007, 02:18 AM
Thanx for the info...gone to git smart.
Old 10-23-2007, 08:50 AM
Andi1's Avatar
Originally Posted by ulrichd View Post
Andi,
Ulrich
Nice to find a fellow Porsche owner in Houston on this forum!....umm I don't have the pump on my car like the photo shows...I was just wondering what it was.Thanks everyone
Old 10-23-2007, 02:53 PM
CT944's Avatar
I want my pump off too. i do not have A/C, so removal of the pump will make the left side of the motor a heck of a lot easier to work on. now i have to research how to 'plug the holes'..
2007 997 TT
1992 500e
Old 10-26-2007, 06:49 PM
