Andy Bullen
andybullen's Avatar
Send a message via AIM to andybullen Send a message via Skype™ to andybullen
how low can you go?
Hey guys - I'm thinking of lowering the SC just a tad below european ride height.
I was interested in seeing how low you can go without disrupting the fine
balance between handling and looks.
On a side note, it would just be interesting to see a car that's been hammered down
as far as it can go, just for posterity's sake......
76 912E - Grocery Getter
04 Toyota TacomaTRD - Beater Truck
08 Honda OdysseyEXL - Family Hauler
Old 05-30-2011, 12:33 PM
rsscotty's Avatar
Not a 911 SC but one of the lowest 964 models I've seen. Maybe it doesn't have to go up driveways.
Old 05-30-2011, 02:35 PM
i actually just raised it up about a half inch to clear my driveway
Old 05-30-2011, 02:45 PM
Member 911 Anonymous
DRACO A5OG's Avatar
You can go about 1/2" below Euro until you will need Bump Stop Spacers to avoid the effects of bump on steering.
We recently lowered a buddies '86 down to 24" Front and 23.5" in the Rear. Whoa that was low
Caveat, you will get extreme Negative Camber up front. he is at -1.8 and completely maxed out on the camber adjustment, hitting the side wall of the strut housing. He may need to raise the fronts or relocate his spindles at $125 each.
Jim
'85 Carrera Targa
PCA/POC
Old 05-30-2011, 02:50 PM
Under the radar
Trackrash's Avatar
My car is 24 rear 24 1/2 front. In order for my car to work at this level, I have raised the front spindles 22mm and installed a bumpsteer kit. I have also installed 22 and 30 mm torsions with cut down stops. With out these mods I would be bouncing off the bump stops over every crack in the pavement.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-30-2011, 03:06 PM
mrk_d's Avatar
Mark
1987 Carrera Coupe
http://nvrmndclothing.com/
Old 05-30-2011, 03:19 PM
DRACO A5OG's Avatar
Wholy Smokes Batman, MARC! She is LOW
'85 Carrera Targa
PCA/POC
Old 05-30-2011, 03:22 PM
Banned
Here's 23 3/4" and 24 1/4" on 16"s.
Old 05-30-2011, 03:26 PM
Driver
Noah930's Avatar
Not mine, but we found out the hard way this afternoon that this is too low. For the street, at least. FG splitter lip caught a raised edge of pavement in the junction between an alley and the street and cracked.
1990 Black 964 C2 Targa
Old 05-30-2011, 07:06 PM
Andy Bullen
andybullen's Avatar
man, that thing is dumped! (blue pre 74)
Old 05-30-2011, 07:38 PM
Andy Bullen
andybullen's Avatar
a little off-topic, but who makes the flares on that 934 look?
Old 05-30-2011, 07:40 PM
my daily
Old 05-30-2011, 07:42 PM
Canyon Runner
70SC's Avatar
I'm @ 23.5 " in the rear & 24" in front with 205's & 245's[img]
Old 05-31-2011, 11:02 AM
MBruns for President
JeremyD's Avatar
Mine is 23.75 and 24.5
at speed
I think the only way I could get lower would be to put on smaller wheels and tires.
Old 05-31-2011, 11:09 AM
FinallyGotOne's Avatar
dropping it will help with the handling and as long as you have the suspension adjusted to compensate there is not really a too low point other than just real life issues. The post office here has pretty high speed bumps and I always drag on them, but I have a forgiving rubber front lip, and fibergass rockers. I had my lowered by a air cooled Porsche shop.
Old 05-31-2011, 11:10 AM
rsrfan's Avatar
AIR flares (old molds. the flares are 20 years old or so) Heavily massaged to look factory...
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 05-31-2011, 11:16 AM
DRACO A5OG's Avatar
70SC & JeremyD,
Any issues with the front Fender Lips, did you guys have to roll the fenders?
Also, could you guys share your front camber readings?
My buddies '86 even with Bump Spacers can only get a max positive camber of -1.8, before we tried to correct it, he was at a whopping -2.4
I suspect a bent spindle or at a minimum relocation of the spindles even with Bump Spacers.
Jim
'85 Carrera Targa
PCA/POC
Old 05-31-2011, 11:48 AM
JeremyD's Avatar
Mines a wide body - so not sure it would help much.
No clearance issues with 255 tires up front - although with my 235 ties and 18mm spacers on my track tires I was getting a little interference and rolled the passenger side a little
Old 05-31-2011, 11:56 AM
DRACO A5OG's Avatar
Thanks for the reply JD,
What is your front cambers set at?
Wow, even with a wide flares you get scuffed? Geez. But she looks awesome
It is painful to be beautiful
'85 Carrera Targa
PCA/POC
Old 05-31-2011, 12:05 PM
Alter Ego Racing
ErVikingo's Avatar
My SC is setup pretty low. Must measure though:
My 2 liter race car is set up even lower:
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 05-31-2011, 12:47 PM
