stv951's Avatar
Best LSD for 915 ?
I am considering to install an LSD to a 915 Gbox. What are the options available apart from quaife ?
I searched at Pelican, but it doesn't sell an LSD for a 915 box. Any directions and opinions please ?
Old 10-10-2007, 01:17 AM
ttweed's Avatar
I think Paul Guard at Guard Transmissions makes the best units. That's what I have in mine. He posts here as "Geary", so do a search on that username or just go to his site and give him a call. The type of LSD you want will depend on your usage of the car.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 10-10-2007, 06:44 AM
Cory M's Avatar
Originally Posted by ttweed View Post
I think Paul Guard at Guard Tansmissions makes the best units....
+1
Old 10-10-2007, 07:30 AM
Mitch Leland's Avatar
Lsd For The 915...
Howdy,
I'm thinking of replacing the missing LSD rear end that was optioned on my car. Someone for some reason took it out. If you're doing 1 or 2 DE track events a month is it worth it?
I have my engine and tranny out now so it would be easy to make the change, less the $2,000 for the Guard LSD unit. I've talked to Paul Guard and he's a good guy with good follow up. And from what I can tell he has the best LSD on the market. If you contact him he'll send out a complete information package to ya.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 10-10-2007, 07:44 AM
I bought a used Guard Transmissions Torque Biasing limited slip for my 72 911 with the 915 transmission. I had previously installed a ZF clutch type limited slip. I use the car primarily for street and autocrossing. The TB diff is GREAT! The car leaves really hard and the turn in slower corners is much improved. If you intend to use the car for track use, the clutch type is much better.
Tom Oxner
Old 10-10-2007, 08:05 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Without a doubt in my opinion. I do maybe one a month when I have the time. I always come away from the track saying to myself I have to get the LSD for my car. I see people do things I just can't do with my car- trailbrake/brake later and power out of the corners with MUCH less wheelspin. If I could limit the amount of wheelspin my car suffers from, i'd be shaving a second or two off my times with ease. Not to mention the tire wear!
Kevin L
'86 Carrera "Larry"
Old 10-10-2007, 11:03 AM
Bill Verburg's Avatar
For De's, From best to worst(but they are all good)
Guard asymmetric 40/60 or 50/80, guard symmetric 40, ZF symmetric 40(early mit 4 plates)
some will argue for a symmetric 80 but IMO that's a race only option
Bill Verburg
Old 10-10-2007, 11:14 AM
Bill and Kevin,
Sounds like it's something I should do. Particularly since the engine and tranny are out of the car and I'm having the tranny gone through. So it would be cheaper now (if cheap is the right word) to have it installed now.
Thanks,
Mitch Leland
Old 10-10-2007, 11:47 AM
Better in Person
juanbenae's Avatar
i just did my 1st DE with my new guard set up and it was unbelievable the difference. i knocked a second and a half off my best time at sears point after one event. i had been stuck at a lap time for the past three or four events there and just like that i was quicker. still i dont feel like ive relearned the car complete like and still i was faster.
will be doing sears again later this month and feel there is another second to shave as i become more accustomed. biggest feel of the difference at sears? from 9 decel into 10, stable like mable...
T$
Old 10-10-2007, 11:52 AM
rpiper's Avatar
I had the ZF in a G class PCA car (with 4 clutches) and it was amazing. Then I had the Guard symettric 40 in a street car; also fantastic. I drove a hotrod RS clone with a quaiffe and didn't like the way it was locked on accell but not on decel, so you'd get uneven engine braking. It really unsettled the car.
Bob Piper
78 911SC "Bullseye" SOLD
00 540i
02 CBR 954RR
98, 00, 03 sons
Old 10-10-2007, 02:48 PM
Less brakes, more gas!
euro911sc's Avatar
If you want to run in PCA Stock class do you have to have a ZF?
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 10-10-2007, 03:10 PM
rpiper's Avatar
technically,yes, but the ZFs are REALLY hard to find and the Guard unit is functionally identical (clutch type). It is no advantage compared to the ZF, and they'd have to tear open the diff to see that you had a chromalloy Guard unit rather than the ZF.
Bob Piper
00 540i
02 CBR 954RR
98, 00, 03 sons
Old 10-10-2007, 03:22 PM
drag racing the short bus
dd74's Avatar
Guards are what? $2K? I've seen the price somewhere, but can't remember.
The Terror of Tiny Town
Old 10-10-2007, 03:34 PM
Bill and Kevin,
Thanks,
The lsd can be replaced now or later after the trans is installed.
Remove the axle and sidecover for access.
Bill Verburg
Old 10-10-2007, 06:25 PM
-Michael
That or an open diff.
Bill Verburg
Old 10-10-2007, 06:27 PM
Britain Smith's Avatar
Does anyone have some details how a LSD is installed.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine
'74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans.
'80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks
-- www.britainracing.com --
Old 10-10-2007, 09:25 PM
Britain,
My mech said that there was some set up to it, and I think unless you really know your way around transmissions and rear ends I wouldn't attempt it. The risk/reward is too high...
Mitch Leland
Old 10-10-2007, 09:45 PM
ipapilot's Avatar
For those concerned with the legality of different diffs in PCA club racing, you may want to weigh in on the proposed rule change that may allow a Guard or similar unit due to the scarcity of the factory units...
Brian Starr
Alabama Region PCA
1983 911SC/Rebodied as 993 w 3.6
1995 911 C2 (Sold)
Old 10-10-2007, 11:37 PM
euro911sc's Avatar
Bob,
Yeah, I know its unlikely they would look there... but I'm one of those guys that will follow the rules even if it makes me last place... I just want my skills to win... not my car... which means I will most likely never win anything but have fun trying I'm ok with that for the moment
Brian,
Where do I send my letter/e-mail? would love to have some options in the future as ZF units are very hard to find...
-Michael
Michael
'13 Cayenne GTS
Old 10-11-2007, 05:52 AM
Schleprock
KTL's Avatar
-Britain
There's a thread on here called "Need Bearing PreLoad Specs" by Dentist90.
Kevin L
'86 Carrera "Larry"
Old 10-11-2007, 06:35 AM
