Dear folks, I have some specific question which is based more on the repair of an cdi.
![]() ![]() When the CDI was assembles I measured with my AC Meter 38V on measure point 2. I had a disconnect ( burned line) between ZD3 & R1. Somehow I had a high current before it go out of function. I checked the 2N3055. Ok The 82V Zenner Diode. Don't know how to test. An now the part which makes me a little unsure in the Thyristor. I have between Anode & Kathode only 48R (build out). That value is strange. I thought it should be high resistance without load. Who can help here. Thank you team. Bob |
Bob,
I know nothing about CDI repair but Warren Hall does. Try reading this thread and if you still have a question, post it as part of that thread. History of Bosch CDI ... toubleshooting info, parts list changes, and schematics ...
As always, when the DIY effort fails, call Pelican Parts,
e.g. Scott, John, Jason, or Wayne if necessary, & save future headaches. Remember, Pelican Parts has many sources for parts which may not show on their website. Bottom line: Sometimes it's not worth it in the long run to be a DIYer for everything.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
Bob,
Is the ZD3 Zener diode shorted or open as tested by a multimeter? If it is still shorted that would explain a burnt trace. Is the SCR shorted from anode to cathode both directions as tested with a multimeter? That can happen after attempting to jump start a 911 with CDI. If you don't mind rewiring a TO-220AB device ... 2N6405 or 2N6509 SCRs by OnSemi will work just fine at a bargain price from Mouser or Digikey. Tab must be insulated from heatsink, though.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Warren the 82V Zenner was checked and ok.
I replaced the Thyristor and the problem was solved. I had a 200V Sinus at measure point 2 due to the fact the Thyristor was short. Do you have the links from Mauser & Digikey. Thank for your help. If you don't mind rewiring a TO-220AB device ... 2N6405 or 2N6509 SCRs by OnSemi will work just fine at a bargain price from Mouser or Digikey. Tab must be insulated from heatsink, though. bob |
"I had a 200V Sinus at measure point 2 due to the fact the Thyristor was short."
Do what? Totally impossible! A mis-diagnosis of the problem and a mis-understanding of the functional operation. Why a DIY effort when a failure of this unit can result in a stranded situation, unless you're going to just keep the car in the driveway and revv the engine? Furthermore, if you have no real knowledge of what you're doing or are getting mis-information, a DIY effort can just result in damaged parts. Again, let Pelican Parts be a source for this part.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Designer King
For those of us who don't know about these things, what is the part in the photo, where is it on the diagram, and what does it do? Thanks.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Bob,
Here are the links: http://www.mouser.com/ http://www.digikey.com/ Paul, That assembly has the three major power consuming semiconductors mounted to it on an early version of the CDIs ... later versions have the power Zener bolted directly to the case.
"Why don't you help the gentleman out"
1. Some shouldn't be rebuilding 911 engines (me). 2. Some shouldn't be rebuilding 911 transmissions (me). 3. Some shouldn't be rebuilding CIS fuel distributors (me). 4. Some shouldn't be rebuilding Bosch radios (me). 5. Some can do their own oil changes & brake jobs (me). So, for items 1-4 most (me) should use Pelican Parts or other sources for labor intensive efforts. Thus, some know their limitations while others attempt efforts beyond their capablities even when helped by knowledgeable others, which may in the long run do a disservice to the DIY, e.g. a future failure because of the DIY's basic inabilities.
Lorenfb,
1. Some have the interest and capacity to learn from others who have the knowledge and willingness to share. 2. Some like the challenge of learning how to fix something, rather than throw it away. 3. Some don't mind spending their time on an interesting project, rather than spending money (even if they have more of the latter than the former). So, while the practical solution may be to have a professional solve the problem, or to buy a new replacement part, many of us prefer to go the DIY route for the enjoyment, among other reasons.
1969 912/6 Coupe 1970 911 T Targa |
Irrationally exuberant
Some of you may not be aware, but Loren does the electronics rebuilds for Pelican.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Jon |
"Some of you may not be aware, but Loren does the electronics rebuilds for Pelican."
Actually no, Pelican Parts has MANY good sources for Porsche parts, or has the capabilities to find them. As a result, this has contributed to their success.
-Chris
Dear all,
thanks to all who supported my questions! The Box is working fine now. It spend about two hours in fixing and I know a little more about CDI Boxes Boxes now. The Thyristor was kind of short to ground. ( Anode / Kathode resistance 48R.) I did not figuered out if the failure path to point 2 was over the (R2)10R & (R3) 52 R & W1. That could be the reason whay I saw 200V Sinus on my scope. Never mind. Thanks you Warren. He is the CDI King on the board. Lorenfb do my a favor, go to Hawthorne & Imperial and get a girlfriend. Your comments are were a big self goal. Thanks again to all. Bob |
That is great news, Bob! Glad to be of help.
Warren can I use the 2N6509 TG as a replacement.
TG for Lead Free. bob |
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Warren could this Thyristor from Ruttosha T048 housing could be replacement for AEG Thyristor.
Bob http://www.mouser.com/search/ProductDetail.aspx?R=16RIA100_1%2f4%22_UNFvirtualk ey64010000virtualkey640-16RIA100 |
