bjarte
Guest
Posts: n/a
Oile leaking: From Where? dangerous? Expencive?
Few days ago, there was maybe a half liter with motor oil under my car, I went to a garage for chequeing it up, but what?
We could not find out from where it came from. It is from the rear passanger side, and maybe close to the oil filter or a little bit under. It do not come from the bottom, and the car maybe still lweaking a drop or two (not much).
My oil instrument in the car has gone down maybe 2 - 3 mm from the top, from top level, and it is still way to the red limit.
What can it be? is it dangerous ? shall I stop driving the car? and, will it cost me a lot of money?
Thanks all of you , I love this website.
From the north
Bjarte Giske from Norway
Old 02-15-2001, 03:03 PM
Nickshu
Guest
Posts: n/a
Yes, stop driving the car. Your engine is more or less oil cooled and being without oil is sort of like a water cooled engine losing its coolant. Not to mention the lack of lubrication that occurs without enough oil. Get some spray degreaser like Brake Cleaner and clean all the oil from the area where you think the leak is coming from. Then fill it, start it and watch it leak to see where it comes from.
Hope \this helps.
Nick.
_ ______ _
Nick Shumaker
1982 911SC Coupe
[This message has been edited by Nickshu (edited 02-15-2001).]
Old 02-15-2001, 04:09 PM
bjarte
Guest
Posts: n/a
Forgot to tell: I have a 911 SC Coupe -79
and about temperature, it runs like normal, It do not get any hotter.
Old 02-15-2001, 04:15 PM
emcon5
Guest
Posts: n/a
Did you recently change the oil? My 82 did the same thing after the place I bought it from changed the oil and overfilled it.
If you did recently change the oil, have a look in the air box, there may be a puddle of oil in there. If the car has not been serviced recently, do what Nick said, and clean it to try and find the leak.
Tom
Old 02-15-2001, 04:28 PM
bjarte
Guest
Posts: n/a
The company I bought it from, I think put to much oil in my car, I heard a 911 have to go(the motor) when you check it, and it is maybe 0.5 cm to much.
What I want to do, is to go to a Porsche garage and tell them to just fix it, IT IS TO GOOD CAR TO NOT DO IT), but I am just afraid this is bad/ heavy excpensive.
Still thanks - you are great.
Porsche lover
Bjarte
Old 02-15-2001, 04:34 PM
emcon5
Guest
Posts: n/a
What I did to fix mine was buy a few feet of clear tubing from a hardware store, and removed the extra oil through the fill tube.
Slow and messy, but nearly free. I think the tubing cost me about $2.
If you are really a cheap SOB, (like me) you can save it in a clean container to add back later when your car has consumed some.
Do open up your air box, you probably have a nice oil puddle in there.
Tom
Who went through this last month.
Old 02-15-2001, 05:15 PM
Superman
Guest
Posts: n/a
We think maybe your only problem is too much oil. it should be fully warm when you check it. Check it when fully warm, and reduce the oil amount if necessary. If the problem persists, then maybe take it to a shop for repair.
'83 SC
Old 02-15-2001, 05:22 PM
movin
Guest
Posts: n/a
My 911 started leaking from the same place. I found out it was the O-ring on the engine oil thermostat. Took at lot of patience to replace that $3.00 part!
From the north
Old 02-15-2001, 07:22 PM
cary
Guest
Posts: n/a
If the oil tank is overfilled. I just found a new to me, tool. Suction Pump. Basically, a big straw. Sold right with the lube guns. I bought it to change mY 915 gearbox oil this spring. $12US @ NAPA.
Cary Kutter
77 Carrera w/3.2
Rennlist #001117-2266
PCA Region - Big Sky
Old 02-15-2001, 08:28 PM
ZE911
Guest
Posts: n/a
Check the "O" rings in your oil returns tubes.
Old 02-18-2001, 02:02 AM
Doug Zielke
Guest
Posts: n/a
My buddy's '78 SC just started to leak a lot of oil. It was the oil cooler seals. We figure the cold temps in this area made the oil a little too thick on startup, and blew the seals. Bummer for him, I gather these are not easy to get at with the motor in the car.
Regards,
Doug
'81 SC Coupe
Old 02-18-2001, 07:54 AM
