So, I found this morning that the airflow switch doesn't open. I have continuity to ground whether I push up on the plate or not.
You're welcome.
Brian
Old 12-01-2007, 12:21 PM
Stranger on the Internet
patkeefe's Avatar
Brian
Thanks!
Now that the Christmas lights are up, I can go back and see what the problem is.
Pat
Patrick E. Keefe
78 SC
Old 12-01-2007, 02:17 PM
I'm having a similar problem which just started. What did you find out with the "safety" switch? I found that I have continuity to ground from either side of the switch, with the plate at rest or lifted. When I removed the connector from the switch and stuff a wire into it to complete the circuit, I get power to the fuel pump. Otherwise I get nothing at the fuel pump.
Interested in your results,
Nathan
Old 05-15-2008, 12:25 PM
