Anyone every Fuch a 993?
Has anyone every put Fuch style rims on a 993? I've been wondering/contemplating this for sometime. I wasn't fully won over by the Boxster earlier this fall we photochopped with Fuchs. I would also likely go bigger diameter if I were to have these made up. I'd NOT go full bling, thinking RSR or painted pedals.
Can anyone try this with a 993 coupe? Its a widebody, so I could use a little dish in the offset Certainly doesn't have to be photo quality, but for us photoshop dumb users free help will have to suffice. Coupe is a necessity and vintage color likely as its a track type car for the photochop if possible (currenly white, though). Thanks in advance for any help. Option two is likely BBS to go the GT-2 look and keep the Grand Prix White.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Former Options Trader !!!
The offsets wont work with OEM Fuchs, nor would they fit over the brakes. I believe you could get some custom made ones from a place like Lindsay but I think they would look odd on a modern car.
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster |
Metal Guru
Speedlines are the new Fuchs for the 964 and 993......
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
A 993 is not a "modern" 911, and the shape is very close to the earlier models, so I think a set of 17 inch Lindsey Fuchs would look good. I don't like the stock 993 (or 964) wheels as they have no dish, and the 993's and 964's I have seen with aftermarket wheels, such as Champions or Fikses, look very good, and IMO much better than stock.
There is a reason why they don’t have a dish, and that’s the offsets are all wrong for that style of wheel. Someone with more specific technical knowledge then I can chime in here. The geometry of the hub and the brake offset in a 993 is much more modern then the Fuched wheel cars. I would consider the 993 a much more modern car then any of the 911's that came with Fuchs. The entire suspension is modern, gone is the torsion bar system. The intake and engine management systems are modern. The HVAC system is modern. Are they state of the art for 2007? Of course not. If you compare them to the engineered systems from the Fuchs wheeled cars they're modern.
That’s not saying those older systems are not good, a lot of us love the way the older cars are engineered. In fact for strength and weight the Fuchs are tuff to beat, they're forged steel. You could take an old tub and create a modern 911, I hardly think the shape is the defining criteria for modern, unless you're pinning that definition completely to aerodynamics. If you’re point was “more modern” vs. “modern” its semantics.
abides.
![]() Edit: I like the MY02 wheels on 964s and 993s.
Graham 1984 Carrera Targa Last edited by gtc; 11-02-2007 at 12:54 PM.. |
Someone can correct me if I am wrong but I believe ALL the real OEM fuchs are forged steel
I thought they were magnesium? there awfully lite to be steel
72 911 82 911 70 GTO ![]() 97 GT Ragtop 74/76 Jeep cj's |
It's an aluminum alloy, actually.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
abides.
I apologize for my sarcasm.
My fuchs are forged aluminum.
Graham 1984 Carrera Targa |
Well, Porsche Doc put Fuchs / Lindsey's on his 964 backdate to early RSR and the offsets looked pretty good. Isn't the offset on the 964 hub about the same as a 993?
![]() ![]() Of course with the Fuchs you'd also need a duck tail!? How's this (I think that's a Getty Dseign part).
Jeremy ![]() 1971 911 Wide One 2.7 2012 911 Cabriolet 2011 Cayenne S |
Yes they're custom made from Lindsay which I mentioned could be made to work.
Canadian Member
some things you just can't fuch with!
[/QUOTE]Wow...I like the Carrera light weights on the 965! I have them on my Boxster S and love them (plus, they are so easy to clean).
'73 911 Frank 'n Meanie 2002 Boxster S PCA Instructor Circa '95 |
Livin' the Dream
I don't know... It just doesn't look right to me.
'84 911 Carrera |
but thats a bad photo shop. it looks like hubcaps. would like to see something with some depth.
http://www.dropfiles.net//files/750/cars%20001.jpg 2003 golf TDI http://www.dropfiles.net//files/750/...aven%20013.jpg 1983 SC |
Bye, Bye.
My 993 Duck with MY 02:
Elvis has left the building. |
Guest
Posts: n/a
^^^ much better! looks good to me. ^^^
Crotchety Old Bastard
Photoshop that same car in black - I'll bet it'll look even better.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
