msd 6 al
I have a msd 6al and there is sticker on the side that states, "Do not use with solid core wires" so what can I do? My wires are solid core, stock Beru wires. 1969 911 2.0 I am not planning on racing just a stock set up using the msd box and hi-vibration coil and tach adapter. Do I need different wires?
Thanks Rob
1987 911 carrera targa 1969 911 T still working on this one other oldies 1968 honda mini trail 50 ko model free bee came in boxes 1981 CR 250 R basket case rebuilt and running |
"farking Porsche hero"
I went with red Clewett Engineering wires from out host.
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" |
I wouldn't use stock wires with MSD.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thank you. I will consider the suggestion and wil not use the solid cores.
RETIRED
If you use solid core wires, you won't use them long....they'll pinhole and/or burn out....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Just ordered the Clewett wires, thanks for the information. I knew there was going tobe a problem with the old wires when I opened the box and read the warning....
Thanks Rob
Irrationally exuberant
I drove a 930 across the country with stock wires and an MSD - worked fine.
Maybe MSD doesn't want you to use wires that don't have resistance? "Normal" wires use some sort of conductor that has a certain resistance to it. The stock/Beru wires have a resistor in the plug connector. If only Warren was still alive, he'd know. (Sniff) -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
MSD doesn't want EMI to interfere with their ignition controls. You can supress EMI in either of two ways. Through resistance or neturalizing the magnetic field by creating a wire spiral carring voltage around a magnetic core.
Resistance lowers the tail end of the spark and/or lowers frequency depending on who you ask. Some pelicanheads have reported failed factory Beru wires and damaged rev limiting rotors when using MSD. The Beru plug connector has a group of connectors carring the voltage. Warren and Loren have discussed this issue. My bottom line is that any age or weakness in either is a problem waiting to happen. I use spiral wire and the simple rotor pn 93060290102. JW says it's the 1972-77 VW rotor. Pelican Parts lists it as Bos-04038 also http://forums.pelicanparts.com/porsche-911-technical-forum/213066-rotor-button-melting-why-2.html#post1832405
They are ment to be used with SPIRAL core wires
Ok for real. How much difference from the CDI box do all you MSD guys notice? My CDI works fine, but my low end power sucks. Below 3K its pretty sluggish.
Darren 1973 911 T MFI 2005 997 Carrera 2001 Toyota 4Runner |
I don't know how much of a difference the msd will make but I got a good price and a complete setup. My car has a lot of missing items and I decided to go with a solid package instead of piecing it together.
Rob
Hmmm. Must be the holes in the insulation caused by voltage "spikes"? ![]() Sherwood |
