Eck Eck is offline
What kind of bit do I need?
What kind of bit does this require and where can I get one? The star bits I have are either too large or too small and I don't want to strip them out, they already look pretty messed up.
Kirk
Old 11-11-2007, 01:24 PM
Eck Eck is offline
That should read "do I need" not "d I need"
Old 11-11-2007, 01:47 PM
sudo apt-get purge 930
equality72521's Avatar
Most call it a triple square bit, it has 12 points. Not sure what size you need.
--clutch-monkey
Door Striker Tool
Eck,
I have this tool for years and don't know what's it is called. You need an 8 mm tool to remove the securing bolts for 911 door striker. Good luck.
Old 11-11-2007, 02:23 PM
What you need is a Spline bit (AKA triple square as mentioned by equality) :
If you can't get from Sears then you can find here from $2.50...
http://www.lara.com/cgi-bin/store/commerce.cgi?keywords=bt-spl
As boyt911sc states you want 8mm (AKA M8 or #8)
Warren & Ron, may you rest in Peace.
Old 11-11-2007, 05:03 PM
AutoBahned
RWebb's Avatar
triple square
avoid asking for a 'spline' as you might get a Bristol Spline - which won't work properly (or if you're lucky won't fit in there at all). It is some British thing with more meat near the center.
Old 11-11-2007, 09:40 PM
An hand impact driver and BFH will also assist in removing these stubborn fasteners.
Sherwood
Old 11-11-2007, 09:45 PM
Thrlls's Avatar
I just purchased a set from here:
Triplesquare
Woody
Slow n Fast
1984 Guards Red 911 Carrera
Old 11-11-2007, 09:48 PM
triple square
Spline bits are called for when working on VWs. My assumption is that these are one in the same.
Here is the tool I'm thinking of. Used for VW/Audi...described as a Spline tip driver for door lock assemblies.
Old 11-11-2007, 09:50 PM
Thrlls's Avatar
Could be the same, as I used a triple square #10? on our Jetta door lock assembly. Except it was a socket and not a driver.
Woody
Slow n Fast
Old 11-11-2007, 10:44 PM
Not sure if the spline tool I've seen is one in the same with the triplesquare. To Randy's point there are proprietary versions of the format.
I only mention this tool as a friend has both the driver and similar bit.
Old 11-11-2007, 10:51 PM
haycait911's Avatar
as mentioned, a 12-point tool AND a product called ' screw grab'. google it, it's awesome stuff. it's like little tiny chunks of carbide in a sticky goo. really makes a good grip between your tool and the fastener.
http://www.frentzandsons.com/eshop/catalog/147.htm
Old 11-11-2007, 10:58 PM
group911@aol.co's Avatar
Oddly enough, that tool showed up in a couple of the later 3.2 tool kits I have. Not sure where else it is used on the car though.
Thanks,
Bob
group911@aol.com
Old 11-12-2007, 07:41 AM
