Original Owner
tsuter's Avatar
Bumper bracket = saftey device????
So what is the purpose of this bracket on the passenger side of the bumper??
Some USA saftey device???
Four bolts mount...see pic. heavy steel.
Wraps around the side a bit and shields the trombone and the horns...
Can I lose it?
Gets in the way of the bellows nuts, bumper extension, fender...
The other side has no equivalent.
78SC.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 11-12-2007, 10:37 AM
Southern Class & Sass
Dixie's Avatar
Yes, you can loose the piece. It's there because of U.S. automotive regulations. U.S. law requires a car be drivable after a low speed impact. (I believe "low speed" was originally defined as 5 mph, and was later reduced to 2.5 mph.) The plate protects the oil cooler from damage in a low speed accident.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 11-12-2007, 11:24 AM
na2ub's Avatar
After you take it off, weigh it for the rest of us.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 11-12-2007, 11:51 AM
Original Owner
tsuter's Avatar
Two lbs 4oz or 1.0kg for the Europeans...
With the four bolts. Lot of crud behind it.....
Its history....
tsuter
Thaaaats Right!!
Old 11-12-2007, 01:29 PM
cycling has-been
bkreigsr's Avatar
was it aluminum?
the early 930's were formed 3mm low grade al bar stock.
still a pita when installing air scoop, or spal fan.
Bill K
Old 11-12-2007, 01:33 PM
Original Owner
tsuter's Avatar
Originally Posted by bkreigsr View Post
was it aluminum?
Bill K
yes aluminum
tsuter
Thaaaats Right!!
Old 11-12-2007, 02:46 PM
It's actually an aluminum extrusion, cut to length and then bent into a curve. There's foam piece designed to fit into the gap between this and the body, to direct more air through the cooler. On most cars, the foam piece is gone. If you delete one of these, you'll have a larger hole to fill.
JR
Old 11-12-2007, 04:50 PM
