Crotchety Old Bastard
RarlyL8's Avatar
CIS Pressure Gauge - $20 and you never have to crack another fuel line.
I fiddle with my CIS a lot. A tweek here and a tweek there to get the best performance, fuel mileage, and driveability that this 20 year old equipment can deliver.
Well I finally got fed up with poppin' off the fuel lines and taking a gas bath. For $20 and an hour of your time you can add a permanent gauge to the system. The only drawback is that you cannot check system pressure unless you also install a T valve. Yes it looks a bit Ford oval or bow-tie but that's my roots and it works for me. I can now adjust the cold pressure in about 30 seconds. Fellow tweekers might like it as well.
Old 10-05-2006, 05:31 PM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Very cool Brian! Can you give us a parts list with sizes? I might have to dig into mine soon.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 10-05-2006, 07:35 PM
al lkosmal's Avatar
That is a very good idea. i'm doing it.
RGruppe #669
http://www.x-faktory.com/
Old 10-05-2006, 09:54 PM
nice
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-06-2006, 03:16 AM
Elombard's Avatar
Where did you find the metric to pipe adaptors? I like it.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 10-06-2006, 03:51 AM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
Nice work.
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 10-06-2006, 04:08 AM
RarlyL8's Avatar
There is a really cool old timy Ace Hardware store nearby that stocks all sorts of odds and ends fittings.
The "T" block has 3 female 1/8NTP recepticals and is made of soft brass (that is key). The stock WUR fitting will screw right in and pull up tight with out stripping. (I had extras that I tested first).
You can install this gadget with the WUR in the car. The one I show in the picture is a spare that I used to make sure it would work and not strip out any threads.
Old 10-06-2006, 04:13 AM
evill's Avatar
Did you install a T valve? I don't see it in the pictures.
Great idea BTW.
Regards
Ed
Basically, I'm One Giant Train Wreck.
http://community.webshots.com/user/evill914
Old 10-06-2006, 04:17 AM
coolcavaracing.com
Kroggers's Avatar
How would this work with the normal 3.0 air box. Will it not be in the way?
Old 10-06-2006, 04:32 AM
wcc wcc is offline
wcc's Avatar
Similar to what Kroggers said. Will it fit under the 930 OEM Air Box? I might be interested in hooking it up if it would fit.
Bill
997.2
Old 10-06-2006, 04:42 AM
Neat idea. It reminds me of a conversation Tim Hancock and I had earlier this year at Hershey about permanently installing a CIS pressure gauge to keep an eye on things.
Brian
Old 10-06-2006, 05:44 AM
JK-81SC's Avatar
Very nice! Best idea I've seen in a long time, since our CIS cars are so finicky about the pressure. One quick check and you know if things are right.
The yellow circle is where the the gauge would go for a stock NA car, right?
Jeff
1981 911SC Coupe - SSI's + Dansk, MSD, AC delete, Heater Backdate, Euro ride height, polygraphite bushings, Rennshift
1998 F-150 4x4 - Snow Time
1998 Yamaha WR400 - Mountain Ride
Old 10-06-2006, 08:31 AM
Elombard's Avatar
Yes that is where the gauge would go.
Old 10-06-2006, 09:17 AM
coolcavaracing.com
Kroggers's Avatar
I want to do this, can someone give some more details on how I would fit it to my car (picture above!!)
Old 10-06-2006, 09:20 AM
19 years and 17k posts...
azasadny's Avatar
Brian,
Excellent idea! I would do that if I was keeping my CIS, but I'm switching over to Webers. My CIS gauge has been hooked up so long, I almost forgot it wasn't part of the CIS!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-06-2006, 09:25 AM
JK-81SC's Avatar
Nice looking, clean engine!
That's why I used your picture to show where the WUR is located.
Jeff
Old 10-06-2006, 12:47 PM
Yellowbird RS's Avatar
X2
1974 Carrera US. Specs.
X/A
Old 10-06-2006, 01:01 PM
BlkBird's Avatar
Nice idea. I have the stock air box and a Kokeln interccoler so I'll have to poke around for a good location.
C.H.
Boost Addiction - honestly, I have it under control
1989 911 Turbo Cabriolet
Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace
ruf-porsche's Avatar
Originally posted by azasadny
Brian,
Art see this post from another Weber Carb Owner
Originally posted by kucharskimb
i have webers. i can't say i've been happy with them. most of the problems i experience--accel pumps, transition, idle circuit, float bowl sight gauge--are said to be corrected with the PMOs. if you give Richard your engine setup, he will set up the carbs to be pretty close out of the box for your application.
If i had the money, i would make the switch to PMOs.
Old 10-06-2006, 07:41 PM
Here's a couple of silly questions. #1- What exactly does the part you installed the gauge onto do? Is it a fuel heater?
#2- What is the operating pressure, & is it different cold & hot?
#3- How do you adjust the pressure if required?
Boilermaker......another young man in an old man's body.
Col.
3-'74 911 targa.
Old 10-07-2006, 03:18 AM
