Warren Hall Student
Bobboloo's Avatar
Originally Posted by Bobboloo View Post
Drain the oil, pull the motor out, remove the intake and invert the motor in case any water got in the intake, squirt some clean oil in the spark plug holes and turn the motor over by hand a few times while adding more oil.
Also leave the sump plate off so the any residual humidity can evaporate.
Pulling the motor is the easiest part of the job ahead of you. It only takes about a half hour. Then clean it like Ingo suggested. If you want you can drop the motor but leave the tranny in so that you don't have to disconnect your axles. If you haven't done this before do a search or ask for some guidance.
Get the motor back together and running as soon as possible. Don't let it sit. Run it with some cheap detergent oil until it is up to operating temperature, shut it off and then drain it. It will clean and dry itself out.
Now you can do your paint.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 11-23-2007, 04:41 PM
Less brakes, more gas!
euro911sc's Avatar
pull that motor all the way apart - every tiny piece
+1 at least to the short block... + if you are going non CIS then you can swap the cams/pistons out as running CIS parts w/ carbs is a bad match.
Your shroud, deck lid, and associated rubber/plastic meted all over that engine. Ergo, several of your cooling fins will be clogged up with crap. If not cleaned properly you will be creating hot spots that will cause you issues in the future.
I know its not what you want to hear... sorry...
Best regards,
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 11-23-2007, 05:38 PM
AutoBahned
RWebb's Avatar
"certainly not what I wanted to hear"
- I know and I'm sorry to be (the first bearer) of bad news. boba pretty much summarized it all above. IT will make a lot more sense in year3, 4, 5, etc. than right now. But it is the right thing to do.
Old 11-23-2007, 07:30 PM
