bboy
Guest
Posts: n/a
How to remove an odometer
Hi could really use some help on how to remove the odometer from my 81 SC.
Thanks,
Brian
Old 02-27-2001, 07:29 PM
ohecht
Guest
Posts: n/a
The whole gauge pops out if you carefully pull it out towards the back of the car. The gauge comes apart after loosening the flathead screws, but the odometer itself is pretty hard to separate or repair without completely disassembling the entire mechanism with special tools and expertise.
I was trying to repair a simple stubborn gear on my trip meter, but left it alone after I got the feeling that one wrong move would have resulted in the need for a total rebuild by a professional.
Olivier
82 SC
Old 02-27-2001, 07:34 PM
JackOlsen
Guest
Posts: n/a
A trick: if the speedometer unit is stuck in place, remove one of the adjacent gauges (preferably the tach) and use the hole to reach through and over so you can push the speedo out.
Jack Olsen
1973 911 T (3.6) sunroof coupe
jackolsen@mediaone.net
Old 02-27-2001, 09:40 PM
