Picked up some parts and tools for my 71
I picked up a few things for my 71 roller. I sure hope I can make this stuff fit. I picked up some aluminum control arms, but I'm not sure what year they came off of. I hope I can make them work
2000 Boxster S (gone)
1972 911s Targa (sold)
1971 911t coupe roller (sold)
1973 911t coupe / 3.2 (sold)
Gruppe B #057
Old 11-24-2007, 06:04 PM
I also picked up this engine stand with the cheaper flat adapter. It even came with a motor.
There sure are a lot of loose wires comming off that thing. I hope I can get it to work. Looks like the brain has been sent in for something.
Gruppe B #057
Old 11-24-2007, 06:10 PM
I havent moved the roller in two years so hopefully this will get me motivated.
I still have some things to do on my 73. I should just drive the boxster.
Gruppe B #057
Old 11-24-2007, 06:15 PM
Damn that longhood hotrod thread!!! I'm going to have lots of questions.
Gruppe B #057
Old 11-24-2007, 06:17 PM
I also got a 914 engine mount. Anyone know what this is worth? It looks new except for the surface rust on the end pieces that arnt painted..
Gruppe B #057
Old 11-24-2007, 06:18 PM
Jandrews's Avatar
What color is that roller? Looks interesting if it is original. Looking forward to watching your project...keep posting progress here and that will motivate you to keep it moving. Best...
JA
John
- '70/73 RS Spec Coupe (Sold)
- '04 GT3 (Sold)
Old 11-24-2007, 06:24 PM
Warren Hall Student
Bobboloo's Avatar
Great score on that 3.2. If I lived closer I would have bid on it myself. Did you buy the 915 the guy had for sale as well? It had the bell housing already cut for the flywheel sensors.
You might want to try and locate a rear shock tower cross member for 72' and up cars. It will have the correct geometry for the aluminum trailing arms. If not you might want to just stick with your 71' rear control arms. There's really nothing wrong with the steel ones. They're just a little heavier but not much.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 11-24-2007, 07:27 PM
I didn't buy the 915. I'll be needing one though. I really wasn't planning on buying the control arms but you know how that goes. The problem with my steel arms are they don't have the sway bar mounts. I guess I could look into the ones that mount to the bolt on the swing arms. I wasn't aware that their was a difference. Do they rub or will they just not work? I'm not afraid of using a hammer to make some adjustments.
Has anyone tried to use a 901 with a 3.2? I have one of those.
Gruppe B #057
Old 11-24-2007, 07:53 PM
The original color is a gold metalic. I will be doing a color change. I havn't decieded on the color yet.
Gruppe B #057
Old 11-24-2007, 07:59 PM
AutoBahned
RWebb's Avatar
I think Sherwood wrote an article some years ago that details all the changes for the Al arms on the earlier cars - no biggie on a '71.
Old 11-24-2007, 10:21 PM
