-   -   Here we go again! Zuffenhaus MS RSR project... (http://forums.pelicanparts.com/porsche-911-technical-forum/379658-here-we-go-again-zuffenhaus-ms-rsr-project.html)
eimkeith 07-21-2015 02:19 PM
Originally Posted by santagrant (Post 8719039)
Where did you find the jig to align the top? Wonder if one could be rented from someone in the SF Bay Area.
By the way, your project is coming along very nicely. You are very brave!
I couldn't find one to buy or rent! :(
(but I'm in the market if you come across any.)
eimkeith 07-22-2015 01:56 PM
More work on the shifter today (need to get back on welding, but it's hard for me to transition back & forth in the proper frame of mind, so I'm seeing the design work through)
http://images.tapatalk-cdn.com/15/07...3625c28ff8.jpg
http://images.tapatalk-cdn.com/15/07...3a7f94f34a.jpg
There's enough going on in the wacko G50 shift assembly as it is; much respect for Wevo and JWest for tackling this for such a small number of cars.
I'm making it worse for myself by putting a 915 shift tower on top - I've got to limit shift lever movement accordingly to work through the vertical 'tube', but still get the travel and angles needed in the tunnel.
The photos above are my 3rd version, 2nd revision (shown without the 915 tower installed.)
I'm printing revision 3 this evening. ;)
Closing in on it.
keith.
(sent from my rotary dial phone.)
eimkeith 07-24-2015 10:32 AM
Ok, revision 4 is a winner. Full fore/aft travel, ample degrees of rotation on the gear selector shaft.
http://images.tapatalk-cdn.com/15/07...246ae2b822.jpg
This is what it will look like with the 915 shift tower installed over it:
http://images.tapatalk-cdn.com/15/07...b88aa7e8b6.jpg
(Imagine a 915 shift lever installed, with boot.)
keith.
DaddyGlenn 07-24-2015 04:40 PM
I am so envious of you, Keith. To be able to spend your days doing design and fabrication on these cars .... and get paid to do it.... nice!
I know you must have bad days from time to time. But I sure it beats the hell outta my desk job.
Keep it up. I'm living vicariously through your posts.
eimkeith 07-24-2015 05:49 PM
Lol, glad you're enjoying the thread.
keith.
eimkeith 07-28-2015 08:24 AM
Quick Tuesday morning update:
I couldn't locate a good original RSR transmission cooler (the end of the road for the hard lines on the driver's side of the Mary Stuart), so I got started on converting an RS-style trombone cooler.
Here's the cooler and the reference photo (photo of '74 RSR):
http://images.tapatalk-cdn.com/15/07...5a2b3aa527.jpg
Right-hand brackets/tabs de-brazed.
http://images.tapatalk-cdn.com/15/07...0d3c8be3fb.jpg
So far, so good!
keith.
eimkeith 07-28-2015 11:06 AM
Back on the roof welding (1/2 completed)
http://images.tapatalk-cdn.com/15/07...683d097f9a.jpg
http://images.tapatalk-cdn.com/15/07...7e9f8deabc.jpg
keith.
eimkeith 07-29-2015 08:30 AM
Cleaning up some rocker rust this morning.
http://images.tapatalk-cdn.com/15/07...589cd25c20.jpg
A little disappointed with the patch panels available, though:
http://images.tapatalk-cdn.com/15/07...d4cd29b223.jpg
keith.
em78911 07-29-2015 09:54 AM
Would you mind posting any pictures you had of the sunroof weld up job you performed?
eimkeith 07-29-2015 02:05 PM
The previous time (welded in sunroof panel) or this time around (replaced roof skin)?
I don't have photos of the first time it was done (I wasn't the primary on this project until the carbon bodywork phase) - but I don't recommend the weld-the-sunroof-panel approach.
keith.
eimkeith 07-29-2015 02:12 PM
Almost wrapped the driver's side rocker repair today (misplaced the lower quarter panel face piece I removed several weeks ago, can't finish this until I find that damn thing!)
Here's some pictures of today's work.
http://images.tapatalk-cdn.com/15/07...e694d60964.jpg
http://images.tapatalk-cdn.com/15/07...cd2bb70bf1.jpg
http://images.tapatalk-cdn.com/15/07...1b6cf5fb70.jpg
http://images.tapatalk-cdn.com/15/07...1d81aad510.jpg
http://images.tapatalk-cdn.com/15/07...96ef716960.jpg
http://images.tapatalk-cdn.com/15/07...5e7bcfe1af.jpg
(Had to slit this piece to narrow it to fit)
http://images.tapatalk-cdn.com/15/07...827464dc76.jpg
http://images.tapatalk-cdn.com/15/07...a68a4e255d.jpg
http://images.tapatalk-cdn.com/15/07...fdfc27dfb3.jpg
Now to find that missing piece.. >:(
keith.
em78911 07-29-2015 06:34 PM
keith.
Hey keith,
yeah , was wanting to see the first plug up.. when you welded a plug in the sunroof... not so much the reskin... thanks.
eimkeith 07-29-2015 07:06 PM
Originally Posted by em78911 (Post 8731528)
Hey keith,
sorry; I don't have any photos of that previous work.
I can tell you that filler strips were used, and a lot of forming is needed to control distortion - that method requires welding in the middle of a relatively flat plane, no natural curvature to resist drawing of the heat affected zone (plus there are two closely spaced parallel lines of weld around the sunroof - making the draw worse.)
hope that helps in some fashion?
eimkeith 07-30-2015 04:21 PM
Worked on the passenger side rocker today (funny how the one with less rust took longer; didn't quite finish it)
http://images.tapatalk-cdn.com/15/07...25d97e32e8.jpg
Down to the good stuff
http://images.tapatalk-cdn.com/15/07...3850ffd733.jpg
Fitting the patch
http://images.tapatalk-cdn.com/15/07...14a1cb8fec.jpg
http://images.tapatalk-cdn.com/15/07...9a68ea513c.jpg
http://images.tapatalk-cdn.com/15/07...c6342d7d5e.jpg
Fitting the top layer
http://images.tapatalk-cdn.com/15/07...1bd176c0b6.jpg
Didn't get a shot of that welded in, but finished the day with welds that need to be ground & finished, then primed.
keith.
eimkeith 08-04-2015 01:28 PM
Working on the 930 trailing arm mount conversion today, but never posted the finished rocker repair on the passenger side, so here it is:
http://images.tapatalk-cdn.com/15/08...11aad4c7b0.jpg
OK, trailing arm mounts.
You'll recall that we're using 930 trailing arms (wider track, massive bearings, etc.) on this build, so we need to modify the pickup points on the chassis.
I modeled up a conversion that visually references the RSR solution in 1973:
http://forums.pelicanparts.com/uploa...1429797196.jpg
I started making the pieces today, using templates I'd printed out to mark the material for drilling & trimming.
http://images.tapatalk-cdn.com/15/08...6a8974ab3d.jpg
Make a pilot drill jig
http://images.tapatalk-cdn.com/15/08...642fc67935.jpg
http://images.tapatalk-cdn.com/15/08...8baf71d9fd.jpg
http://images.tapatalk-cdn.com/15/08...d6d79b60d1.jpg
Similar tolerances to original trailing arm bolt holes.
Here's the fitting work on another G50 housing:
http://images.tapatalk-cdn.com/15/08...df24b2305f.jpg
http://images.tapatalk-cdn.com/15/08...48532dd484.jpg
keith.
eimkeith 08-04-2015 01:36 PM
My (symmetrical) installation tool doesn't line up with the transaxle mount on one side of the mock up torsion bar housing, surprisingly.
http://images.tapatalk-cdn.com/15/08...ef87e7a374.jpg
I'm assuming there are deviations during manufacturing so I'm modifying the file and printing another install tool, this time with slotted holes at the transaxle mount.
I've also concluded that I will in fact need to cut welding access holes in the rear seat pan (thought I could avoid that) to install these mounts properly.
Such is life!
keith.
eimkeith 08-05-2015 05:40 AM
Alright, back at it with new install tool (12 hr print)
http://images.tapatalk-cdn.com/15/08...745c00cf42.jpg
Hard to see here, but ample clearance for locating hole now.
http://images.tapatalk-cdn.com/15/08...cd00ce5663.jpg
keith.
eimkeith 08-05-2015 06:11 AM
Access!
http://images.tapatalk-cdn.com/15/08...582fb715c2.jpg
Fitting to the cast portion of the torsion bar housing:
http://images.tapatalk-cdn.com/15/08...021778e03e.jpg
http://images.tapatalk-cdn.com/15/08...539fab35b6.jpg
More work needed here for proper fit.
keith.
eimkeith 08-05-2015 07:26 AM
And tacked in.
http://images.tapatalk-cdn.com/15/08...a8e5ada1fb.jpg
Now to mock assemble the suspension and set up the car to verify alignment before finish welding and adding the bracing.
keith.
jjeffries 08-05-2015 01:05 PM
Fascinating, superb and overall uber-cool design and workmanship. John in CT
