Go Gators!
s2per's Avatar
creative intake system
While looking on ebay the other night, I caught this longhood with a really unusual intake.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=290185295079&ssPageName=STRK:MEWA:IT&ih=019
Not very good engine pictures, but it looks like a single 2-barrel carb to me. I'm old enough to remember aftermarket 4-barrel intake systems available for 140 hp Corvairs. Being a "purist" (or should I say "broke teenager") , I kept the stock 4 1-barrel set-up on my Corsa; you should've heard it when the secondaries kicked in!
Man, when did I get to be a geezer?
Timothy Stoops
Air '62 356 B-‘86 911 Cab
H2O '12 Cayenne
Old 11-30-2007, 04:59 AM
jluetjen's Avatar
Given the use of the singular in this comment "Carburetor may need to be adjusted", I would tend to agree with you. It looks like someone took the CIS system off and replaced it with the carb. I think that you can see the capped injectors in this picture.
Compared to CIS, it may not be a bad change from an airflow perspective, but I can only imagine what it must be like to start on cold mornings, with the fuel dropping out of suspension through those long cold runners, not to mention uneven fuel delivery to the different cylinders.
Another "hack job" in my opinion. It may work, and it may be cheap, but I doubt that it's optimal. It might be a good negotiation point to drive down the price, or scare off other bidders.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 11-30-2007, 07:49 AM
Monkey Butt Forespin
84_Carrera's Avatar
A local-to-me guy has this exact setup on his. The CIS was ripped out leaving a dinky little single carb prior to his buying it. He was "unhappy with the performance" if I recall correctly.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 11-30-2007, 08:14 AM
