davis911s
Guest
Posts: n/a
Question Measuring rim width Fuchs
Hi another question. How do you take the measurement for a rim? Is it from the inside of the lip to the inside? Or outside to outside?
With the Fuch rims is there not a number stamped on the inside of the rim indicating size?
Thanks Again guys
Old 03-06-2001, 02:21 PM
ChrisL
Guest
Posts: n/a
Post
Fuchs do in fact have a number stamped on them. Bruce Anderson's book has a table showing these numbers, size and offset. If you post the numbers here I can look them up for you.
Chris.
Old 03-06-2001, 02:29 PM
Jim T
Guest
Posts: n/a
Post
The number will be stamped on Fuchs wheels.
That is the definitive answer.
I can't tell you how many times people have thought they had eights (or at least they claimed that they thought they did, usually when they are selling), based on their "measurements."
Old 03-06-2001, 02:30 PM
RarlyL8
Guest
Posts: n/a
Post
Inside it inside will get you close enough to the nearest known wheel size.
Old 03-06-2001, 02:32 PM
davis911s
Guest
Posts: n/a
Wink
Thanks I will look for these numbers, are they easy to spot? where are they on the spokes or lip?
Shawn
Old 03-06-2001, 02:40 PM
Early_S_Man
Guest
Posts: n/a
Post
Shawn,
The part number and width, i.e. 7J x 15 ... are on the backside of the spokes, and you may have to clean off the brake dust/road grime to see them clearly!
Warren Hall
1973 911S Targa
Old 03-06-2001, 02:56 PM
Charlie Moore
Guest
Posts: n/a
Post
They're on the back side of the wheel on the inside of a spoke - my 8x16's are marked 8JX16
Charlie '87 Carrera
Old 03-06-2001, 03:00 PM
