CAR IS 77 CIS--GOT HOME FROM DRIVE CAR RUNNING GREAT--
1 HR LATER,WONT START--FIRES LIKE NORMAL FOR 1 SEC THEN RPM DROP OFF TO 0 MOTOR STILL WARM--TRIED NEXT MORN.--SAME THING I PULLED FUEL PMP RELAY & IT WONT FIRE AT ALL. W/ RELAY IN IT FIRES THEN DIES, NO MATTER WHAT I DO W/ GAS PEDAL NEVER SEEN THIS BEFORE--HOPEFULLY SOMEONE HAS THANKS - |
I HAVE NOT SEEN ANYTHING LIKE THIS BEFORE
LOUD NOISES!! UMMMM.... WHY EXACTLY ARE WE IN CAPS ANYWAY?
66 911... no more 90 mazda miata 76 unimog 406 Dune Buggy! |
Do you have a pop-off valve? If so, could be stuck open or come loose and allowing air into intake. Symptoms are classic for a leak in the airbox somewhere, although you didn't mention anything about backfiring. Easy to check out.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
I don't have heaps of experience or anything, but something similar happened to me. One of my injectors had popped out of the manifold and was hanging loose. Symptoms were similar to yours. I pushed it back in (push fit - strange) and then it ran fine from then on!
'78 SC Coupe with a turbo wide body, Zender bodykit, 964 electric rear spoiler, 911r taillights and new/old sports seats... |
I checked the p.o. valve-- ill check the injectors, but wouldnt loose
injector spray gas everywhere unimog--sorry the caps bothered you-- im not real comfortable w/ a keyboard |
The position of the gas pedal shouldn't be a factor in starting a 911 engine unless something is wrong. And, then that's not right, if you follow me. Yes, a loose injector would spray and be dangerous AFA fire is concerned. If your car ran fine up to the point it was parked, if might not be that anyway. The symptoms you describe seem to be fuel and/or intake related. I had a '77 for 15 years. Let me think a few more minutes. |
Thanks milt
maybe????, it is just firing off of the cold start injector, and there is some reason that the injectors are not metering fuel. Maybe try to lift the air sensor plate, and see if you can hear it inject fuel.
No left turn un stoned |
when i did my search prior to posting- the only simptoms that matched were a car that ended up being out of gas! my gage shows 1/2 full.
my next step will be add 6 gls from gas can. ive had work late the last couple nights.ill add gas wed. i can hear gas in tank- cant tell how much. again,sorry for previous caps-i didnt know! |
If the engine starts and then immediately dies both warm and dead cold, this could be an interesting problem. I wonder if the fuel filter is at fault. How it would suddenly clog is beyond me unless it ate some water. I believe a fuel pressure test is in order.
the same w/ the gas thing-yes the gage could be erratic--but it was running great when i pulled into driveway.
but ill take it a step at a time |
1st step--add 6 gl gas
2nd step-- fuel pres. check-- ill let you know thanks |
The problem ended up being erratic fuel pump operation
-- replaced pump--runs great now |
