machintek
Guest
Posts: n/a
Post Where did the window go?
Had an interesting event. Had a car pull up alongside and motioned for me to lower my window. I tried, hearing the mechanism move but the window did not. When I opened the door, the window dropped. It will come up and I must assume that the glue gave out that hold the window to the actuator frame. Has anyone had this occur to them and how did they remedy the situation.
George
83 911SC Cab/Euro
Old 03-05-2001, 08:49 PM
feelyx
Guest
Posts: n/a
Post
I had the same problem on mine, it turned out to be the window channel, that the window slides up and down in. When it wears out it lets the window cock sideways and binds it in the channel. Thus your mech goes down and the window stays up until you touch it and then it falls. Replacing the channel was a little time consuming, but well worth it.
Tim in Sac
Old 03-05-2001, 09:02 PM
fred hannah
Guest
Posts: n/a
Post
same thing happened to me(1970 911t 2.2)but the window tape was bad on mine. i went to a glass or window repair shop and got a new strip and the problem was solved. took awhile to get to the inside of the door and get the window to seat back in the track, but after that i havent had a problem scince.
Old 03-06-2001, 09:37 AM
campbellcj
Guest
Posts: n/a
Post
same here, a few weeks ago my driver's-side regulator let go. It's the early scissors type that is held together by rivets. Now I know rivets don't last forever.
I drilled out the rivet and put in a machine screw and nut; seems to be holding up fine so far.
Old 03-06-2001, 09:58 PM
