Ambitious Outsider
sabeo.m's Avatar
Question Head Studs?
What do you guys think of ARP head studs? Any good?? [img]
1988 3.2 Cab
2005 997.1 C2S
Old 12-03-2007, 06:13 PM
Irrationally exuberant
ChrisBennet's Avatar
IMO, they are an expensive waste of money.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-03-2007, 07:07 PM
don't necessarily stay tight either.
206 637 4071
Old 12-03-2007, 07:14 PM
cameron.arnott's Avatar
What are the best options guys?
Cheers, Cam
'74 RS 3.0 Replica
Porsche 968 Clubsport SOLD
'70 911E Bahia Red SOLD
'71 911 S/T Replica 2.3 Twin plug BEAST SOLD
Old 12-04-2007, 02:11 AM
resident samsquamch
sand_man's Avatar
This discussion was slanted towards a 930 engine rebuild, but still some good info. FWIW, in a turbo application (and I relize that's not what you're inquiring about) "upgraded" head studs like ARP, Performance Developments, Supertec, etc. are pretty high up on the build sheet. Of course there are different forces at work when you toss a Turbo into the mix! YMMV...
Advice on Head Studs for 930
-jeff
Old 12-04-2007, 04:04 AM
Slumlord
Porsche_monkey's Avatar
You might get different responses in the engine rebuilding forum.
Old 12-04-2007, 05:36 AM
Absolutely true.
Stick with the 993TT studs and you'll never go wrong.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-04-2007, 08:30 AM
Senior Member
Superman's Avatar
Cheap, used, factory plain steel studs.
Mocha 1978 911SC. "Coco"
Old 12-04-2007, 08:53 AM
JBO JBO is offline
I would (did) go with the factory 993 steel studs a few years ago. They are not that expensive, and due to the high cost (or amount of work involved even if you can do the work yourself) of removing and tearing down the engine, I would not use used head studs, though I know others have done so apparently successfully.
Old 12-04-2007, 10:53 AM
Bill Verburg's Avatar
I used 993tt/RS/GT2 studs on mine.
993.101.170.51 x24
They used to be very reasonably priced
Bill Verburg
Old 12-04-2007, 11:12 AM
I thought the ARP studs were the best you could buy,acording to the pelican engine rebuild book ????? FM
Old 12-04-2007, 05:47 PM
