Sneakin' 'Bout
MFI overhaul reccomendation
Hi, I have 1971 911E and need to overhaul the MFI system There are multiple vacuum leaks and worn parts. As far as i know, no work has been done to the system since the car was new (36 years). I live in the San Francisco Bay Area and was hoping someone could recommend a good reliable shop to take it to for fixin. A place called Po Boy's in (fruitvale?) was recommended, but cant seem to find any contact info, anyone ever hear of them?
1971 911E Canary Yellow w/Mahle wheels and AC
Old 12-05-2007, 08:57 AM
GrantG's Avatar
I think Gus at Pacific Fuel Injection is one of the most recommended resources.
Pacific Fuel Injection Service
Gus Pfister
153 Utah Ave,
South San Francisco, CA 94080
(650) 588-8880
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 12-05-2007, 09:11 AM
Autodidactic user
David E. Clark's Avatar
The two most recommended places in the California area are:
Pacific Fuel Injection (Gus Pfister)
Suite B, 153 Utah Av
Tel. 650-588 8880
Jerry Fairchild Industries (Robert Turner)
5242 Westside Rd
Redding, CA 96001
Tel. 530-241 1592
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 12-05-2007, 09:15 AM
Gus Pfister
153 Utah Ave,
(650) 588-8880
+++! For Gus @ Pacific FI.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-05-2007, 09:25 AM
Crusty Conservative
silverc4s's Avatar
Gus Pfister is the go to guy for pumps and injectors in your area. Last I knew he did not rebuild throttle bodies, though.
You might also contact Henry Schmidt at:
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
He is very active on the board here and generally has helpful answers to the really difficult situations that we mortals get ourselves into..
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 12-05-2007, 09:28 AM
304065's Avatar
It depends on what's worn out.
"Multiple vacuum leaks and worn parts" on a '71 implies that there's something wrong with the throttle bodies or the stacks. This could be as simple as changing the gaskets or as complex as having the throttle bodies rebuilt by somebody like Matt Blast at www.eurometrix.ws.
What else is worn out? If you click in David's signature line you will find the "Ultimate MFI thread" that has many links to the various subsystems: pump, thermostat, speed switch, stacks, throttle bodies, correlation, etc. If you can identify what's acting up, or at least post the symptoms, we can steer you to the right sources to fix everything.
I am not aware that there is as extensive an assembled collection of MFI information OR experienced operators anywhere in the world other than right here, so WELCOME to the forum.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 12-05-2007, 09:29 AM
Tree-Hugging Member
Jim727's Avatar
"Yes" to everything above. Gus is definitely the guy for pump rebuilds. If you are also looking for a shop that can help you with the overall project, Billy McNair at European Performance in Novato (415-382-8394) is excellent.
Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners.
Old 12-05-2007, 10:37 AM
+1 for Henry at Supertec. He can handle the whole job for you.
Old 12-05-2007, 11:13 AM
Zeke's Avatar
The essential difference between Pacific and Fairchild is not performance. It is the level of restoration. Fairchild is less money and rebuilds pumps to work, not as a show piece. Pacific does a perfect job on both aspects using freshly plated parts for completely restored look.
From what I've seen on MFI, they can get worn, but I bet a lot of pumps are "rebuilt" needlessly. You should see the inside of these things. They are built like tanks. Throttle shafts are another matter. So is the linkage.
Old 12-05-2007, 11:15 AM
Autodidactic user
Don't forget this list of MFI tuners and rebuilders from the Early 911S Registry website.
Old 12-05-2007, 12:48 PM
Tree-Hugging Member
Jim727's Avatar
David - I don't see Holleran's in Pinole, CA, on the Early 911S list. Any particular reason? I thought they were supposed to be quite good with MFI.
Jim
Old 12-05-2007, 01:40 PM
Autodidactic user
Jim,
I don't know why it was left off and since I've never heard of them I can't make a recommendation one way or the other (maybe others will chime in). They do have a website, Hollerans Performance, but there is no mention of MFI on it. Anyone familiar with their work?
Old 12-05-2007, 02:46 PM
