abcdefghijklmnopqrstuvwxy
htron435's Avatar
Will this 17" tire size combination work?
I have an '81 SC that I'm looking to put 17" tires on. Will 225-45-17's fit on the front with 245-45-17's on the rear? I have access to some used Kumho v710's in those sizes to go on a set of 7.5 and 9.0 Fikses. Will this setup work?
Jay
2010 Spec Iron Mustang NASA GLD #113
(sold)1981 SC Coupe 3.6 (in '74 Carrera clothes)
(sold)1999 Spec Miata NASA GLD #113
jaynorthauto.com
Old 12-06-2007, 06:44 PM
efhughes3's Avatar
Those will work fine.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 12-06-2007, 06:50 PM
KCinBR's Avatar
Last saturday I mounted my new Rota Fox 17" wheels with 225/45 x 17 on the front and 255/40 x 17 on the rear and have not had and problems.
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 12-07-2007, 03:29 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Jay,
Those sizes will work, albeit not ideal since the rear tire is a little taller than the typical Porsche 25" overall diameter.
The 245/45-17 has a theoretical OD of 25.7 in., so you'll have gearing that's a bit longer. A buddy had magical handling 225/45 and 255/45 Toyo T1-S (no longer manufactured) tires on his 17x8, 17x9 Ruf Yellowbird wheels and they fit okay. His car has a slammed ride height and most likely rolled front fender lips. Rears were no problem at all and even had thin 1/4in. spacers he eventually took off.
Kevin L
'86 Carrera "Larry"
Old 12-07-2007, 06:54 AM
