Engine starts not normal
Hello
After my engine swap from (2.7 to 3.2) I can start my 3.2 engine BUT NOT as is should be If I turn the key to the first contact I have voltage on the ignition coil. When I turn over the key to start the engine the engine won't start! When releasing the key the engine starts. I checked the following: Key on first contact: voltage on the ignition coil Key turning to start : no voltage anymore on the ignition coil When releasing the key the engine turns just a little bit and the bobine gets back its voltage and starts. But it's not how it should be I also checked the DME relais resoldered the connections but I don't know where to search anymore Anyone has some idee's? |
Topic can be closed!
Problem solved : one wire wrong connected . |
Thread Tools | |
Rate This Thread | |
