nuts and bolts and washers, oh my
So a question for all ye gathered here, if you were going to put together a supply of nuts, bolts, washers, etc. to keep on hand, so that not every repair required a call to Pelican of trip to the hardware store, what would it be?
Let's not go crazy, we know we can't keep everything we might need, but a list of items generally used, if such a list exists, what would it be? Thanks. Tom |
I'd start will valve cover (crush) washers and nuts and depending if your car has Carrera tensioners, the crush washers for the oil fed tensioners. All of these are critical to stopping possible leaks if they are disturbed from initial install.
Tony G 2000 Boxster S |
I keep 21 old Japanese motorcycles around....Can usually find what I need somewhere in that mess......
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
I'm not sure if you have these types of stores in your area but it's worth looking into.
This store sells hardware, bolts, nuts, washers, etc by the pound! You can mix and match in one bag and be out the door for a few bucks then separate at home. Or take a container, weigh the empty container and fill it with hardware and pay for the difference in weight. http://www.ksurplus.com/ And this place is excellent as well. http://www.marshallshardware.com/ They had about 95% of evertyhing I ever needed. Check to see if you have these types of stores where you live. |
I would just buy the nuts, bolts, washers, etc. I needed as a project progressed, since they are readily accessable from plenty of sources. Since you can't predict what projects you will have in the future with much accuracy, you can't predict what assortment of fasteners you'll need. So you'll have a bunch of stuff left over you'll never find a project to match.
Marv Evans '69 911E |
I bought a few assortments from Pelican. Click on "Accessories" at the top of the page, then click on garage gadgets. It's a little money up front but cheaper in the long run than buying a few items at a time.
JR |
I have collected so many nuts bolts washers screws tappets valve shims studs zip ties electrical connectors pins orings C clips over the years and have sorted them out into 12 compartmentaiized containers that I can do a project without ever needing to buy another screw ever.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
UnRegistered User
I have seen packages of fasteners for sale on eBay from one of the auto dismantlers that sells their parts online. I don't know what you would end up getting, but it might be worth looking into..
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Engine Hardware
I just finished a clutch job and while I'm there projects to my engine. I went back with all Stainless Steel hardware. Most of it is 6mm and 8mm bolts and nylox stop nuts. I think it has a nice look and certainly will wear well. Albeit it cost more than your cad plated hardware. S.S. doesn't have the tensile strength of grade 5 or better hardware, but for most of the accessory applications that isn't a problem.
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
For your porsche, I recommend an asortment of:
6 mm bolts, 15mm long to 25mm long, 10mm hex top, for engine sheet metals and others 8 mm bolts, 20mm long to 40mm long, 13mm hex top, for most other attachments 8 mm bolts, allen heads, 50mm to 60mm long, for CV joints, pressure plate, and strap 10mm bolts, 12mm bolts 4mm sheet metal screws for fender and stuff The special 8mm hollow nut for the tensioner line (either 12mm head or 13mm head) There will be that one time when you snap one and have to wait for express delivery (I did). 6mm nuts, nylon inserts 8mm nuts, nylone inserts and non nylon insert 8mm nuts, 13mm hex heads, bronze exhaust nuts 10mm nuts 12mm nuts 10mm barrel nuts for your head studs (always have a handful on hands) and the special hardened washers Washers of variouus sizes, flat, lock, wave You want to have some orings (return lines etc), some sheet metal stuff, some zip ties The bad news is there are no kits for this. Any kits you find will just cover 40% of this stuff. Unless, wayne wants to put a kit together, but then its prices will be high.
AutoBahned
most can be had from a local hardware store
I would keep some washers and cap screws for the CV joints handy - you may find one partly stripped and the washers really ought to be replaced each time (not that I have always done so...) The cap screw is a special high strength item and the lock washers are similarly rare if not more so. |
Here in Denver we have:
AAA Metric Supply 60 Lipan St. Denver, CO 80223 303-892-9000 They have almost everything. There are also dozens (hundreds?) of local suppliers of more general metric hardware and such. For more special (Porsche part number) hardware try the many good independent shops and we have two good local Porsche Dealers. Overnight from Pelican works. If you have a local Porsche recycler, work a deal with them to totally dismantle a 911 similar to yours. They get your labor and you get every nut, bolt and washer. I have several hundred pounds of original hardware from salvage over the years. Hardware ‘kits’ are useful. Best are standard metal ‘bins’ with various assortments. Look on FleaBay. Those will usually have junk for hardware but the boxes are very useful. Example: ![]() I have about 50 of these boxes left over from Rennenhaus. You can see this is a combination of Porsche part numbers and commercial hardware. Many shops have similar collections. It is worth your time to explore every possible local source; industrial, Porsche, other German & Japanese, junk yards and more. Knowing where you might find something you need is invaluable. Most good shops have an extensive collection because no one wants a project to stop for want of some piece of hardware. Just like you. Best, Grady PS; NO, I don’t sell any hardware so please don’t ask.
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
I bought the Wurth Metric starter kit and added nylok nuts in 6,8,10mm. More than enough to do a couple restoration projects. The bins are great but $$$
http://www.wurthusa.com/project/en/leftnavi/catalog/product.php?path=01.3030.jpg Martijn
'66 3.2 "Blue Car" '73 3.0 "Orange Car" '78 3.2 "Brown Car" |
Non Compos Mentis
I've had a few parts cars. After all the big items are stripped, I have gone around the car removing every nut, bolt, washer, screw, yada yada before getting rid of the hulk.
I've got several little bins of Porsche fasteners. It's pretty amazing how light a 911 tub is- When removing the rear bumper shock bolts before scrapping an '87 tub, the entire tub lifted off of the rear jackstands when using a 3/8 ratchet wrench. |
Anyone know where to find yellow zink fasteners?
I've looked every where but found nothing so far.
Silver 1980SC Euro coupe |
The thing is, there are not that many sizes of bolts, it's all the different lengths. One too long is always better than one too short. You can cut it down if need be and chamfer the threaded end. When it comes to nuts, well you don't need a huge assortment. But do get some spring washers and flat washers. Porsches don't use very many split type lock washers. Mostly spring and some Schnorr types. Lots of flat washers, especially against any soft metal. It's pretty common to see washers doubled up with one lock and one flat. In the smaller bolt sizes and especially electrical connections, tooth type lock washers are seen often. |
Ron,
I think it's hard to get all the hardware finish to match. If you're really concern you can have a plater either run your hardware in Zinc or Cad Type II (yellow). If you have structural bolts such as shock hanger bolts I would ask the plater to "bake" those parts. I've started to put a clear spray on my cad, it dulls the color some, but hopefully it will hold up better.
AutoBahned
"Porsches don't use very many split type lock washers. Mostly spring.."
- I think Zeke means the "wavy" type spring washers here -- the ones that are not cut anywhere, with a circular wave going all the way around. |
