Guest
Posts: n/a
Help!!! Just got my Paris Rhone alternator back from a rebuilt. The terminal labels were removed during the cleaning process...and now I'm starting to doubt my pre-removal sketch. The back of the alternator has three terminals: One a 10mm and two 8mm. I know that the two red wires go to the 10mm. The Bentley manual tells me that the blue wire attaches to the D+ terminal. Which one is that? According to my sketch it is the 8mm next to the voltage regulator (ie if you look at the back of the alternator, the 10mm is to the left of the voltage regulator and the 8mm D+? is to the right). Is this correct? Also, the new voltage regulator that has been installed interferes with the air guide. Anybody have this problem? Very frustrated...should have taken pictures.
Bruce ------------------ Bruce 1982 SC |
Guest
Posts: n/a
Bruce,
The lower left is the D- terminal, the lower right is the B+ terminal and the top center is the 61 terminal B+ - Red Wire D- Brown wire 61 - Blue wire Hopes this info helps. Steve |
Guest
Posts: n/a
If you have any doubts, the brown wire is GROUND, and an Ohmmeter should confirm that the D- terminal has continuity with the frame of the alternator!
------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
Bruce,
Porsche offers a redesigned air duct to fit the Paris-Rhone installation: PN- 911 106 033 05 ------------------ Doug '81 SC Coupe Canada West Region PCA |
Guest
Posts: n/a
Thanks for all of your help. I got the alternator in today. My sketch even makes sense to me now. Thanks again,
Just wanted to thank you all for this post. I was in the same boat and did the search and came across this post. Exactly what I needed and I wanted to thank you all.
Michael
1999 996 C4 Cabriolet 1997 BMW M3 (Hail) 1985 928 S (Sold) 1982 SC Targa (Sold) |
