Dog-faced pony soldier
What penetrates the engine cover?
The shroud that sits atop the engine (green for a 2.7 in my case) has a centrally-located rubber grommet through which the alternator wires pass. There is also this odd penetration on the [edit - DRIVER'S] side of the car through which nothing seems to pass. Is this just a vent or something? I'd figure the stuff under the shroud would be plenty well ventilated due to the big giant air impeller blasting air under there all the time, but who knows. . .
Anyone know what's supposed to go here? TIA.
A car, a 911, a motorbike and a few surfboards Black Cars Matter Last edited by Porsche-O-Phile; 12-10-2007 at 06:15 AM.. |
Actually, that's the drivers side on my car. It goes to the oil vapor canister on the passenger side.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
You are correct (my mistake) - it's driver's side / odd-numbered cylinder bank. Photo is taken looking towards what would be the rear of the engine.
Looks like P/N 000-043-205-16-M136 Here in the Pelican catalog: http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ENGoil_pg6.htm (I'd post the parts diagram too, but for some reason it comes up with the diagram for a 959 instead of a '74 911, go figure) Is this correct? Do you know where it's supposed to connect to on the engine? I'm guessing I have a connection point blocked off somewhere then seeing as I don't have any oil geysers when the engine is running. . . Hmmm. . .
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
A hose should run from that port in the shroud (on the 1,2,3 cylinder side) to your gas vapor charcoal canister, located in the upper passenger side of the engine compartment. The canister is a black, oval shaped container.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
OK I'll look for a spare/un-used port on the cannister. Does the other end of the hose connect to anything on the 1-3-5 side or does it just penetrate the shroud and terminate there, allowing the crankcase fumes to get "blown" out by way of the impeller fan and resulting airstream?
This seems to make the most sense - that the P.O. just hacked off the vent line which is the "stub" that's seen left. I just need to figure out where the other end goes if that's the case - there's probably a nipple on the cannister with nothing plugged into it I'd guess.
