-   -   Darth Vader's Helmet (http://forums.pelicanparts.com/porsche-911-technical-forum/381843-darth-vaders-helmet.html)
onboost 01-29-2008 01:41 PM
Gertvr..
Hey man, glad to see an update! She's looking real fine...
What roll bar is that you're using and where does it mount on the front?
Paul,
81turboporsche 01-29-2008 04:45 PM
That looks Gorgeous,Let the force be with you...
efhughes3 01-29-2008 06:48 PM
What is your flooring, and do you like it?
rattlsnak 01-29-2008 06:56 PM
Do the drilled holes on the rotor on the right side spiral 'frontwards' like in the picture of the left side? Looks like they might be on the wrong side..
Gertvr 01-29-2008 07:51 PM
Good observation. I saw that when i took it out of the box before installation. Phoned customer service and they indicated that all rotors they have seen from Zimmerman were like that and it wasn't a problem. I don't know if there are other folks with the same type rotors that can comment. Think i will start a new thread and post the question to the brake experts on the forum.
Made by Kiwi tiles. I like it a lot the floor isn't as cold in the winter, doesn't care about any moisture, or cracks in the slab and cleans easily .
tws930 01-29-2008 10:32 PM
Please send more pics of your progress. This makes me jealous! My hats off to ya.
billybek 01-30-2008 05:50 AM
Wow!
w21055 01-30-2008 07:51 AM
Subscribed and looks like a Paint shop located for me as well.
Project looks awesome!!
MIK911 01-30-2008 05:57 PM
Dang, what an awesome job!! It's looking outrageous!
Is Princess Lea more pleased with it now?
rennch 01-30-2008 10:02 PM
That is a shiny pile of happy goodness.
Porsche_monkey 01-31-2008 05:31 AM
Originally Posted by billybek (Post 3736947)
Wow!
ditto.
3.2Carrera 01-31-2008 06:29 PM
Car looks great, cant wait to see it when its all finished up !!
What is your motor set up going to be?
Gertvr 01-31-2008 07:42 PM
Good Drawback
Thanks to everyone for the kind words, its really good motivation.
It has a 78SC motor and I am keeping it stock for this phase. Planning to go to ~300Hp in th near future as 2nd phase. Will probably go over to the dark side, hmmm kinda fitting. Working on the rough plan for that but want to do something interesting.
Yep. gotta finish it soon otherwise I'm going to get in another type of trouble ;)
I made a very frustrating discovery day before yesterday when it dawned on me that i forgot to install the shift rod and tried as I might couldn't get the darn thing in. I read some folks got them out without removing the engine but i couldnt get it in reversing their procedures either and it looked like the engine had to come out again bid bummer. In most of the threads that i read it was to get the rod out to install a Hargett shifter.
I had a new RennShift Shifter and coupling ready to go in. There was just no way that i was going to remove the engine again. Decided to sell the RennShift and bought a Hargett shifter. I saw it once and liked the shifter position but already had a new shifter so Ii let go of the thought. It worked out well or so I hope. So far I have just read good feedback. I will relocate the handbrake, hand throttle and defrosters to the original shifter opening.
Progress:
Installed the roll bar
Relocated the ign coil and removed the stock fuel filter and accumulator.
To do this weekend:
Install in-line fuel filters
Install drive shafts
Wiring for wide band A/F ratio meter
Test oil lines for leaks
Check for oil pressure
Start the engine :D
( Spell check didnt work, please excuse my spelling :o )
http://forums.pelicanparts.com/uploa...1201836056.jpg
http://forums.pelicanparts.com/uploa...1201836111.jpg
Spot for the wide band O2 on the HE
http://forums.pelicanparts.com/uploa...1201836214.jpg
Rollbar
http://forums.pelicanparts.com/uploa...1201836247.jpg
http://forums.pelicanparts.com/uploa...1201836339.jpg
lateapex911 02-01-2008 10:28 AM
Tell me your thoughts on the wide band o2 sensor. A permanent gauge? A temporary item to tune the carbs?
Gertvr 02-01-2008 10:56 AM
Hi Lateapex: I will use it primarily to tune the carbs for now and later to tune / run EFI. I will remove the sensor and gauge once tuning is done.
Gertvr 02-21-2008 10:54 AM
Progress Update
Its been a while since i posted any updates. Work is progressing slowly. but i am getting closer to the end date, at least to get this phase done.
The most amazing thing was to start the engine the sound was just awesome, better than anything i have personally heard in a long time :D. The aluminum flywheel, PMOs, SSI and M&K 2-2 transformed the engine's characteristics completely. It is very responsive and feels rev happy. I will be able to get the full jist of it after the system has been fully tuned, at least the initial indications are good.
I had a set of Corbeau Forza seats that i salvaged from my AutoX Miata before i sold it and will be using this until i have the funds to install better seats. I will use Schroth 4 point ralley harnesses as they have an anti submarining mechanism and they are DOT approved.
I think this build is really getting to me now i.e. getting tired and start making mistakes, i have been working on this between 30-40 hrs per week usually ending at 1am in the morning since i got the car back from the paint shop in December. Good example is forgetting to put the shift rod in before installing the engine. This leads to installing a Hargett shifter (was a good thing in the end after recovering from the initial shock, no issues with that), this leads to relocating the hand brake for the Hargett shifter installation, this leads to drilling a hole through both fuel lines in an attempt to reuse the hand throttle. :o
Work completed since the last update:
Completed AFR installation,
Removed damaged fule lines and installed new ones
Installed the Hargett shifter and relocated the handbrake assembly.
Installed temporary seats (they will have to do until i have enough funds to upgrade to better seats)
Completed the passenger door assembly
Installed new drive shafts
Started the engine ( one valve needed readjustment, did that)
Installed front wheel spacers
Work still to be done:
Complete driver door assembly,
Install 4pt harnesses
Bleed the brakes,
Hood and deck-lid alignment
Set timing
Short Test Drive to warm up engine
Check again all suspension and other bolt and nut torques
Adjust Clutch
Tune the Carbs
Set ride height and get alignment done
Chase small electrical problems
Modify window washer fluid container to fit in stock position with IROC bumper
Shake down drive in mountains
Track day @ TGPR on march 19th :D
http://forums.pelicanparts.com/uploa...1203618577.jpg
http://forums.pelicanparts.com/uploa...1203618629.jpg
http://forums.pelicanparts.com/uploa...1203618704.jpg
http://forums.pelicanparts.com/uploa...1203619966.jpg
[img]http://forums.pelicanparts.com/uploads12/P22100081203618903.jpg
[/img]
http://forums.pelicanparts.com/uploa...1203618957.jpg
http://forums.pelicanparts.com/uploa...1203619019.jpg
http://forums.pelicanparts.com/uploa...1203619046.jpg
Rgrds
Gert
DarkSideDe 02-21-2008 11:05 AM
Gert,
It looks all ready to attend the Original Dark Side Driver Ed at Roebling on May 3-4. Hope you will consider it.
matt4hand 02-21-2008 11:07 AM
Gert,
hang in there bud ! It's looking sweet and will be done before you know it. Then you can start your next project....
billybek 07-10-2008 02:26 PM
Hey,
Just checking some of the threads I had subscribed to and this is one that I am curious about!
Any updates?
Gertvr 07-10-2008 03:15 PM
Update
Hi Billybek,
The car is running great and is a blast to drive. I had a shake down day at TGPR in Alabama and attended a couple of AutoX events and two DEs at Road Atlanta with the Porsche & BMW clubs, i will post some pictures as soon as I have them.
In the mean time, I upgraded the rear calipers from 84+ Carrera to 996 rear with the TRE adapters and some spacers. I have an issue, what i think is a suspension setup problem, that i need to work through. The car gets little squirrelly in the back on hard braking at the end of the Road Atlanta back straight. It did this before the brake upgrade. I think i have to much rake (1.7deg) front to rear and will have the back lowered before the next DE in August to see if this changes. I also had problems with the throttle cam ratios changing from CIS to PMOs and had to make some modifications to get the ratio's to provide a decent pedal travel to WOT.
http://forums.pelicanparts.com/uploa...1215727804.jpg
http://forums.pelicanparts.com/uploa...1215727908.jpg
http://forums.pelicanparts.com/uploa...1215727953.jpg
Cheers
Gert
