Lights on pegs tank gauge & kills oil gauge?
Just started today on my 70T. When I pull the light switch my gas gauge pegs at max and the oil level gauge dies. When I shut the lights off both gauges return to normal. Headlights (hi and lo beam)work fine.
Any idea what's happening? Thanks.
Ulrich
Old 12-11-2007, 01:18 PM
304065's Avatar
Short in wiring behind gauges. Disconnect battery, remove gauges, note where the wires have chafed/melted together, replace with factory wiring.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 12-11-2007, 02:22 PM
Thank you John.
Ulrich
Old 12-11-2007, 02:27 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
might check your fuses too.
i know when the #9 fuse blows on a 914 all kinds of funky things happen to the gauges and lights till it is repaired/replaced
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 12-11-2007, 02:33 PM
Grady Clay's Avatar
This can also be the ground for one or more instruments. It reverses the current flow through the "Gauge" circuit. This can actually damage the oil pressure sender, fuel level sender and oil level sender.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 12-11-2007, 03:44 PM
i would think it's a ground issue also. at least that's what i would check first. see that all the brown ground wires are present and attached to the gauge bodies and on the proper ground terminal of all the gauges, for instance, an oil pressure gauge would have 12V, a ground and a sender signal wire in a group of three. each terminal would be marked as such.
206 637 4071
Old 12-11-2007, 03:51 PM
Well I think it's time to come clean. I let the pos terminal of my battery accidently touch the chassis and it sparked. Stupid I know, but there it is.
I have checked the fuses and they are all ok. I found no charred wires on the back of the combo gauge. Here's situation:
- Headlights work (hi/low)
- Blinkers work
- parking lights out on passenger side
- Brake lights work
- License plate lights are out
- Gauges are lit except for the above mentioned combo gauge
Could have been worse. Any advice on how to start?
Ulrich
Old 12-11-2007, 04:41 PM
"farking Porsche hero"
Rich Lambert's Avatar
"parking lights out on passenger side"
- Check the bulbs. If they're good, check for power & ground in the sockets.
"License plate lights are out"
- Same as above.
"Gauges are lit except for the above mentioned combo gauge"
- Same as above.
"...gas gauge pegs at max and the oil level gauge dies..."
- Try disconnecting the sending units and see if the gauges are still pegged. You may have fried them or the gauges. Check for power & ground at the sending unit plugs. Sending units are easy to replace. The individual guage components in the combo guage are replaceable too.
Good luck...it seems like whenever I do something like that there's a screwdriver with a partially vaporized tip involved.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 12-11-2007, 06:38 PM
Thanks Rich. Good advice on the sending units,
Any idea on the lights. If the fuses and bulbs are ok what do I do?
Ulrich
Old 12-11-2007, 06:45 PM
Ulrich
If the lights and fuses are okay, try tracing the power and ground circuits as far as you can. It could be that some of the contacts in the light switch are fused together in the lights-out position. If that's the case, I think you're going to need a new light switch. If your feeling brave, disconnect the positive power wires from the light switch for the license plate lights and the passenger parking lights and run a jumper from the wires to a postive power source. If it's the switch, the lights should work.
I was looking at the schematic for the combo gauge and both gauges and the lights use the same ground wires. You might double check those too.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
Old 12-11-2007, 07:20 PM
Thanks Rich, that gives me a path to follow.
Ulrich
Old 12-11-2007, 07:37 PM
That happened to me once, although it wasn't my fault. Completely killed my first Porsche.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 12-11-2007, 09:59 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
One thing to mention: Shorting the battery in the way you described won't really damage anything but the battery or the ground wire to the chasis. The current flowed between the positive pole across the chasis to though the ground cable to the negative pole of the battery. If your car had modern semiconductor devices these could have been affected by the transient. However, your issue does not seem to be related.
Measure the voltage between a chasis point and connector labeled GND on the gauge in question while you turn the lights on. I agree with outhers that you have a spotty GND somewhere (lights, gauge cluster) that causes your issues.
Good luck,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 12-11-2007, 10:24 PM
