Yellowb1rd's Avatar
Recalibrating a 911 Tachometer...
Anyone know if the Dakota Digital SGI-8 will work on recalibrating a 911SC tachometer? Any help is appreciated.
http://www.dakotadigital.com/pdf/SGI-8B.PDF
Old 12-13-2007, 02:17 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
What exactly are you trying to accomplish?
The Porsche flat-6 produces 300 sparks per second at 6000 RPM. The SC tachometer should indicate 6000 RPM when it sees the 300 Hz signal. Is yours slightly off or are you trying to adapt the tach to an entirely different engine configuration?
In any case from looking at the PDF manual this module appears to be able to do both; slight changes in sensitivity as well as full factors.
Cheers,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 12-13-2007, 04:16 PM
Yellowb1rd's Avatar
Thanks for the reply! My latest project is a SBC V8 conversion using existing 911SC tachometer. Shops want like $180 to do this, but I can buy one of these for less than $100, and do it myself, if it will work.
Old 12-13-2007, 04:58 PM
ischmitz's Avatar
Yes, I saw it online for 79$ - seems to be worth a shot. Apparently, this is exactly what it was designed to do. I would go for it. Good luck.
Old 12-13-2007, 05:05 PM
aftermath's Avatar
bump, did this work? I have the same issue left on my conversion
theamsoilguy@hotmail.com
Old 02-25-2008, 03:18 PM
