ID of Relays Behind Dash
I have no turn signals and also no emergency flasher. So, I pulled the two guages on the left and pulled some of the relays behind to have a look. What I see are from left to right [looking thru the guages] in a block of 4 sockets
1] silver tall metal relay, 944 615 113 00 which I think to be the AC relay 2] tall black plastic relay, 944 615 116 00 which I think is the power window relay 3] empty socket 4] short black plastic relay, 111 953 227 00 which I think is the flasher/turn signal relay Are these in correct position? The Flasher relay will fit in either socket 3 or 4. I have no flasher or turn signal placing the relay in either socket. thanks |
sudo apt-get purge 930
1) AC
2) Power windows 3) ? 4) Flasher/turn signal You are correct, not sure about the positions though.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
The correct flasher relay has five blades (as opposed to pins). They come in other shapes if after market. Factory is black squatty and square. My $10 NAPA relay is still working fine; I tried that first.
1971 RSR - interpretation |
The flasher relay i have and assume is bad is a 3 blade relay [as is the one pictured here at PP]. Maybe the aftermarket types have 5? That would seem odd.
I put a new flasher relay in this morning and still have no emergency flasher or turn signals. Fuses are all good too. Hmmm
I remembered that I removed the door buzzer/seat belt timer a while back. That is what goes in the empty socket I had noted above. |
Digging this thread back up after a continued problem I have with no turn signal/emerg flasher. Looking at the wiring at the relay socket for the flasher once I removed the socket from inside the dash and notice that it has 5 wires leading in to it. The three-spade flasher I have only hits on two of the connectors. There isn't a connector for the third spade. I thinK I'd like to find a 5-spade flasher as DW SD mentioned. Might you have a part number for that??
thx |
