The alternative to the RS door handle.
Hi,
The plastic handle broke off on the third day after installed. I went to the cabinet shop and these might be a good alternative. Let see what you guys thinking. Please vote Burint ![]() ![]()
The Unbreakable RS/RSR door pull http://thaiporsche.shutterfly.com/776 86, 930. 70, 3.2. 67, 911. |
Have you seen.. Fiat 500 door handles?
They look the same as
83sc targa BBT |
Some people are using the metal grab handle from a 356 door.
Keep it Porsche!
Henry "Form Follows Function" 1987 Triple Black Carrera Coupe 1968 Polo Red 911L Barn Find 5/6/06 http://forums.pelicanparts.com/porsche-911-technical-forum/281343-1968-911l-barn-find.html PCA Potomac Region "There's one thing that gets more looks than a new 911............an old one."
Henry,
Thanks for a great suggestion. What does the 356 grab handle look like and where can I find them? Is it the one on this pet?
http://www.wevo.com/Products/BodyTrimProducts/WevoBodyTrimProducts-RLiteHandle.htm
Wevo makes some nice ones. |
And only 78.00 a piece!
![]() ![]() Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Yeah, but that is only $77.00 Canadian!
Bussmuggler
I think that EMPI makes reproduction pull handles that look an awful lot like the 356 ones...only much cheaper. How about an old leather belt and some rivets?
Bussmuggler
Former Options Trader !!!
Cost no object WEVO's are sweet
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster |
You can also use the 356 padded armrest/ door pull. I do not think the hardware store option is well suited for your car. I like to stick with something the factory may have plucked out of the parts bin back in the day.
RSBob posted a nice DIY door pull project using nylon webbing about a month or so ago. It's not 911R-authentic, but neither are most of the door pull options shown above, and it's lighter than all of them.
![]() http://66.236.61.177/showthread.php?t=379247&highlight=door+pull Sherwood |
![]() I won't even bother to give you the vendor. I'll see if I can do better. Someone in the last couple months posted on using this handle for the RS type door panels. I'll keep looking...
Henry "Form Follows Function" 1987 Triple Black Carrera Coupe 1968 Polo Red 911L Barn Find 5/6/06 http://forums.pelicanparts.com/showthread.php?s=&threadid=281343 PCA Potomac Region "There's one thing that gets more looks than a new 911............an old one."
abides.
I've also heard about using the Fiat 500 door handle. Here's a picture of one:
![]() The store I pulled this picture from sells them for 1.8 euros. For that price you could afford to stock up on them and replace as needed. Edit: Oh, and I've seen the cabinet door handle solution before. It's pretty tacky.
Graham 1984 Carrera Targa Last edited by gtc; 12-27-2007 at 02:04 PM.. |
Bussmuggler
Would suggest a pair of early MGB door handles (GLZ118) - 4.5" centres, otherwise very similiar to the Fiat handles but considerably more robust:
![]() See http://www.zeni.net/trf/MGB-GC/220.php Martin 911SC 3.6 |
The trick to long-lasting original RS pull handles is knowing how to use them. Use it to set the door in motion, but then let go and allow the door to close on its own. If you slam the door closed like an old Chevy, they will break every time.
1983 AUDI Turbo Ur quattro 1987 PORSCHE 944 turbo |
Martin,
The MGB, what kind of material do they made of? Thanks for the suggestion.
The handles seem to be made of black bakelite (or dense plastic?) c/w with a pair of (stainless?) steel brackets.
As mentioned they are significantly more robust than the RS handles albeit with slightly larger fixing centres and were recommended to me as an effective replacement for the Fiat rubbish although I am yet to install my set. Martin |
sorry, couldn't resist. Thinking about it from the uninitiated girlfriends point of view, having a "high performance car" with "Fancy smancy door panels and handles..that you can't pull on...seems ...ummmm...humorous.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
