Banned but not out, yet..
RSBob's Avatar
Safe Rust Removal?
People on 914 World who have tried it swear by it - definitely worth checking out http://www.safestrustremover.com/
Old 12-27-2007, 07:46 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Wow, I know those pics are probably "best case", but even if it can work half as well as advertised, that's some amazing stuff.
I may order some - I have a couple of spots that need treatment and if I can get it to bare metal before sealing with POR15 or a similar product, I'll definitely do it. Very cool!
Black Cars Matter
Old 12-27-2007, 08:35 PM
3.2 CAB's Avatar
I have always used a product, that is basically the same product as the name brand "OSPHO" I have bought it in 55gal drums, from the plant in New Orleans. It cost about 25% of what the "OSPHO" product cost. The only drawback is that you can't use it on chrome or pot metal items.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-27-2007, 11:26 PM
Matt
mhoffman's Avatar
same thing as "Naval Jelly"- it converts hematite iron oxide to magnatite. Need to rinse really well after application, and then paint over. Available at most ardware stores is a pint size bottle...
It is basically phosphoric acid in a gel carrier.
79 SC Targa
87 m491 Targa
73 BMW 3.0 CS
73 BMW R75/5
88 BMW M6
Old 12-28-2007, 05:39 AM
3.2 CAB's Avatar
I have never had satisfactory results using Naval Jelly. The metal prep and rust remover that I use is actually a liquid. It almost looks like a cross between antifreeze and windshield washer fluid, in its color. It has been very useful on everything I have used it on. If you have a part that looks like it is totally bad because of rust, I have found that if done carefully, it will remove all of the rust, but it will leave the factory paint intact. It seems like the product could be used for about 4 different degrees of rust removal.
1. It will remove all surface rust with just a short time soak, then rinsed.
2. It will remove all surface rust and all paint, and leave a fresh bare metal finish, then rinse.
3. A prepped steel body panel, can be sprayed with the product, then left to dry. It will then have a protective coating, which looks almost like you have sprayed a clear coat finish on to the body panel. This is great for fairly long term storage to prevent rust while being stored and waiting for assembly and paint prep. EXCELLENT!!!!
4. You can actually dip steel body panels, trunk lids, tailgates, etc. and let the item dry, then dip again, let dry then dip again, etc. It will produce a parkerized like finish. See:http://en.wikipedia.org/wiki/Parkerize
This product that I use, originally came from the oil patch, being used on off shore oil drilling platforms. It is applied and let to dry, then painted over, to protect the metal on the rigs. i have been using this product for many years now, and I really don't know what I would do without it anymore, it is just to easy to use, and has so many ways it can be used. the down sides that I have found are very few:
1. Use on ferrous metals only.
2. Do not use on galvanized, chrome plated, or pot metal items.
I have made several, specialized dipping/soaking tanks, for various applications of different sized parts. One other neat feature of this product is that after you use it to clean up your parts, it can be recycled for further use at another time, by running it through a coffee filter to remove the sediment. I have some of it that I know is at least 5 or 6 years old, it still works great. It is an item that I have come to be dependent on in my shop. It just works sooo good!
Newest additions-
others...
Old 12-28-2007, 09:46 AM
They show a derusted bicycle rim. What do you suppose that was made of?
This would take some burden of the sand blaster, for sure.
Warren & Ron, may you rest in Peace.
Old 12-28-2007, 10:01 AM
RSBob, I read the information on the web sight and ordered a gal. and will see if it is a good as the sight claims.
Old 12-28-2007, 04:46 PM
HarryD's Avatar
A quick search on the web reveals that the product is most likely molasses and water. It works very slowly.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-28-2007, 06:07 PM
heiliges blechle!
They dug that Belvedere up a few months ago - part of Oklahoma's centennial celebrations. It looks like they are going to restore it - 50 years underground in a vault does bad things to a car.
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 12-28-2007, 06:34 PM
