Ruf 18s on a narrow body 88 Carrera
Would these Ruf wheels 18x8.5 ET 58 w/225-18 and 18x10 ET 66 w/265-18 fir on an 88 narrow body carrera?
Charles
Old 12-28-2007, 11:38 AM
I don't think so, as you'd need to use spacers to compensate for the late-style offset, and you'd likely have problems with the rears.
Ruf wheels for your generation of car are 17".
The 8" & 10" x 17" wheels are for the CTRs. (Which apparently have wider rear flares than SC/Carrera, but it's subtle).
The 9" & 10" x 17" wheels are for 930's.
The Ruf wheels for SC/Carrera flares are 8" & 9" x 17:
The 8.5" & 10" x 18" wheels are for 964/993/996 etc.
http://www.rufautocentre.com/parts/pdf/wheel.pdf
'77 S with '78 930 power and a few other things.
Old 12-28-2007, 12:12 PM
KTL KTL is offline
Schleprock
KTL's Avatar
I bet the rears would be easier to fit than the fronts. I've seen 16x10 on the rear will custom offset- no oil line relocating, no massive camber, no spring plate bolt shaving.
8.5 is just too wide up front with narrow fenders. A custom spacer of around 28-30mm would get you around where you need to be with the wheel. You'd certainly have to remove the damper shaft cover and replace it with a rubber bellows, plus you'd have to really massage the front fenders by shaving them and pulling the arches out. 8.5 is just a bit too wide. The tires would certainly rub on the rear inboard side of the tub if you didn't use steering rack spacers.
Kevin L
'86 Carrera "Larry"
Old 12-28-2007, 01:03 PM
Thanks for the insight and chart from Ruf.
Charles
Old 12-29-2007, 07:52 AM
