removing cooling housing strap
I can't seem to remove the strap for polishing. Should it just slide out of the two slots at the bottom? I don't want to force anything without making sure that's all that needs to be done.
O2 In Sully We Believe |
Yup,, puzzle. Take out the distributor. Wiggle, curse, add a little oil, wiggle some more and keep the kids away.
Old Tee all 911s sold |
Thanks Old Tree, but the distributor needs to come out?
Friend of Warren
Yes it does.
Kurt V No more Porsches, but a revolving number of motorcycles. |
thanks
Throw it on the ground!
Hey Mark, you could always go with one of these stainless beauties from Rennline! Unfortunately, I don't think is would "pop" unless the fan housing was powder coated.
Anxious to see your work after all put back toegther. Looks great so far.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Thanks, am having fun.. WOW that whole unit does look pretty cool. Still need to get the dang thing off!!! Am off to the garage for an attempt.
I took my time wiggling it out, w/dizzy removed, to prevent creasing it from bending.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Somatic Negative Optimist
Yep! Turn the engine to Z1 with the rotor pointing to the notch in the distributor housing.
Pry on the bottom of the distributor with the L-end of a small pry-bar straight up. Good time to service the distributor. ![]() Distributor service (Clean and lube) real easy without removing the pinion gear!
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
