question: upsize wheels, do I need to change lug/nut?
I am not sure which is lug and which is nut, I mean the female one. It's the lug right?
I am upsizing wheels/tires to 17x9 and 17x11.5 now. Do I need to get steel lugs or can I still safely use the black aluminum lugs? Do I need to increase the torque or still 96lb/ft? Thanks.
Fat butt 911, 1987 |
You can use without problems the black aluminium lugs with upsized 17" wheels.
cdrik,
Thanks. Someone, more than one, suggested to use the steel lugs for better safety. Meaning these aluminum are not safe? Agree, disagree? Does anyone has any opinion on this?
Open ended steel nuts come w/ different seat configs as well but are only needed if the sanctioning body requires them or if the bolts are too long. torque remains the same regardless of the material. All should be rechecked after driving for a while.
There are LUG NUTS, the 'female' part you are talking about and LUG BOLTS or studs, the things that stick out of the hub that the nuts screw onto.
Aluminum are safe. Some tracks (or organizers) only allow steel, though. The bolt seat, as Bill said, needs to match the wheel. |
While I agree the aluminum nuts are fine for street use you should have one steel one on hand to check one thing, how many threads your lug nut is catching. When using a non-stock wheel or spacers you can easily cut by half the number of threads engaged. For me, unless the steel nut is filled with lug then the lug is too short for that wheel. Of course the opposite can happen also and the lug be too long for the enclosed type nut and in that case all steel open lug nuts are a must.
Gary R. |
in conclusion, there 2 things to check:
1- shape of wheel's seat. On this one, I can compare betwen my Fuch's seat and the new wheels, or place the stock nut on the new seat to see if it's perfect matched. 2- thickness of wheel's seat, to make sure the lug come out long enough and lug/nut bite the same length as on Fuch wheel. Am I correct?
Fat butt 911, 1987 Last edited by rnln; 12-29-2007 at 05:29 PM.. |
Registered Abuser
Steel is a good idea, for track use. Extra margin for safety.
Aluminum are fine until you twist the hex off and leave the nut face
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
"twist the hex off"
This doesn't have anything to do with wheel/tire size/weight, I assume? Only on usage (open or tighten the bolts) or accident. Am I correct?
