Johnny B's Avatar
Help Identifying gearbox
Hello Guys,
Am I correct in thinking this is a G50 from a 1987 911 3.2 Carrera
no is 950301102 3R and the engine no he gave me was 63H***** so motor is definately a 3.2 1986/87 I think
Challenge your limits, don't limit your challenges
911 RSR Jagermeister replica (Sold)
1987 944 Turbo cup (Sold)
Old 12-02-2009, 03:18 AM
Almost Banned Once
sc_rufctr's Avatar
Sounds correct.
Why are you worried about it? Get it in your car already!
- Peter
Old 12-02-2009, 03:27 AM
gearhead
What you have posted there is a casting number off of one of the cases. If you flip it over and look at the rib on the bottom side there should be a serial number stamped on it starting with G50. It is a G50/01 from a 3.2l Carrera based on the picture, but if you post the complete serial number we can tell you if it's an LSD unit or not.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 12-02-2009, 05:24 AM
Johnny B's Avatar
thanks for info much appreciated.
It has 50/00 stamped on the underneath, below is another photo how does one tell if it has lsd or not?
Old 12-04-2009, 03:43 AM
gearhead
What follows that g50/00 next? That's not the whole number.
You can also spin a flange and see what direction the opposite one turns to see if there's an LSD in there. An LSD will have the opposing flange spinning the same direction.
1974 914 Bumble Bee
2009 Outback XT
Old 12-04-2009, 05:57 AM
Johnny B's Avatar
thanks ,looks like 73H after that and then I need to clean it up a bit to see the balance of the numbers clearly
Old 12-04-2009, 06:13 AM
