Typical Salesman
jeffrey2's Avatar
Front bumper causing poor idle?
I backed my SC out of the garage to remove the front bumper for a respray; After removing the bumper and 1 H4; I started it back up and it idled like it was running extremely lean and kept popping after I'd press the gas.
I guess my question is...is there a ground in the front bumper that causes a poor idle? I put stabil (gas stabilizer) in it a few weeks ago since it knew it would be sitting for quite some time.
Does Stabil or the like sink to the bottom of the tank creating an extra lean mixture of fuel?
"No Porsche should be subjected to the humiliation of a daily commute."
1979 SC Targa - Judy
2010 Lincoln Nav - The Purple People Eater
2008 MBZ E350 - Daddy-O
Old 01-02-2008, 01:53 PM
burgermeister's Avatar
Vacuum leak? I think there is a vacuum reservoir (silly term, I know) someplace in the LH front fender ... if there is, and the hose going to it is disconnected, you've got a big leak.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 01-02-2008, 02:24 PM
Typical Salesman
jeffrey2's Avatar
That must be it; a vacuum leak; I'll ck it out on the left side and see what I pulled...
Thanks + my favorite Simpson's quote is "They were the suckiest bunch of sucks that ever sucked".
Old 01-02-2008, 03:37 PM
Peter V
TexasPete2720's Avatar
Good to know, awsome info
VECCHIO EURO 82 SCWDP
2 Hogs & A Diesel Truck
Old 01-02-2008, 05:15 PM
Typical Salesman
jeffrey2's Avatar
Admittedly, I'm an amateur; but cannot find any vacuum hose/line in the front where is it?
Old 01-19-2008, 09:39 PM
Danny_Ocean's Avatar
Driver's side fenderwell, waaay up. You may have to remove the tire to get up/in there. Assuming your car is stock, you should see a charcoal cannister.
Old 01-19-2008, 11:16 PM
That's not where the charcoal canister typically hides, it's where Porsche put the fuel expansion tank. It is located above the large washer fluid reservoir and has two small braided cloth-covered rubber hoses attached to it with hose clamps. There is no way you could have done anything to either of those, by pulling a bumper off. You have to remove the reservoir to get near it. The two lines that are attached to it pass through the inner fender and run back towards the rear of the car along the joint between the fender and the inner fender. I'd look there first.
There is always the possibility that the timing of these two occurrences is just a coincidence and they are unrelated.
JR
Old 01-20-2008, 05:27 AM
pozee's Avatar
Jeffrey2,
Did you jack up the front end by any chance? Another possibility could be that the car sat at an angle w/low fuel and some residue at the bottom of the gas tank shifted and is now clogging up the mesh screen at the rear outlet. The popping sounds like some junk going through with the fuel.
pozee
Old 01-20-2008, 06:10 AM
Whatever...to the layperson, it looks like a charcoal cannister.
Old 01-20-2008, 06:33 AM
3.2 CAB's Avatar
Danny, you are correct about the charcoal cannister being in the underside of the left front fender. It was located there for some applications, while others were in the engine bay on the right side.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-20-2008, 07:41 AM
