safe's Avatar
Top Dead Center sensor
Where does this thing go and what does it "read"? The part diagram is not that clear.
Magnus
Old 01-06-2008, 09:00 AM
3.2 CAB's Avatar
As far as I know on a 3.2, the TDC sensor is only used for diagnostic testing, not an engine running requirement, other engines may vary.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-06-2008, 09:05 AM
Racer
preston_brown's Avatar
+1. That is a bracket for the TDC sensor that is only used for diagnostic purposes. The sensor fits in the bracket and then a wire leads to the back of the engine where the plug for the sensor is capped off with a little yellow cap. It is bolted up near the idle stabilizer valve.
Preston Brown
Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn)
1965 356 C Coupe | 2010 F250 (support vehicle)
Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera
Old 01-06-2008, 11:11 AM
safe's Avatar
OK, good to know. Thanks!
Magnus
Old 01-06-2008, 12:32 PM
scarceller's Avatar
Does anyone know what the 3 pins in this plug are for?
I assume gnd, signal from TDC diag sensor, but what's the 3rd?
I actually have to use this TDC sensor for some timing calculations I'm making for another crazy project.
Thanks.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 10-08-2008, 07:55 AM
safe's Avatar
Shield.
Magnus
Old 10-08-2008, 09:58 AM
scarceller's Avatar
Originally Posted by safe View Post
Shield.
Safe,
So the 3 pins all are basically used for the TDC Diag Sensor only? Meaning the wire harness ONLY goes between the Diag sensor and the connector with the 3 pins?
So the sensor has 2 outputs ('+' & '-') and a shield?
Sorry for the dumb questions but it's a pain to trace in the engine bay.
Thanks.
Sal
1964 356SC (SOLD)
Old 10-08-2008, 10:18 AM
safe's Avatar
Sal
Yes and Yes.
Magnus
Old 10-08-2008, 11:22 AM
