fred cook's Avatar
Cool Alternator leads.............
Does anyone know of a reason that the alternator leads should not be lengthened? By adding about 6" to the existing wires, access to the back of the alternator for replacement or repair would be made much easier. Before jumping in and adding the extensions, I am leaning on the combined knowledge of all Pelicanites for a "Yea" or "Nay" answer!
Thanks,
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 01-08-2008, 09:55 AM
Thanks,
How often are you planning on removing your alternator? How about those little nuts on the fins?
Will the wires touch anything hot if you make them longer?
Rick
88 Cab
Old 01-08-2008, 10:52 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Aside from a slight increase in loss/resistance I can't think of how it would really affect anything.
Black Cars Matter
Old 01-08-2008, 11:12 AM
fred cook's Avatar
Cool Alternator wires...............
The wires already run thru the opening in the end of the air direction vane body. I was thinking of adding a couple of loops to support the wires so they would not rest on the engine block. I don't know what the resistance of 6" of 12 ga. wire is, but it can't be much. I will dig out the volt/ohm meter when I get home and find out what the resistance will be. Actually what I was thinking of adding was a master plug for each set of wires. That way I would not have to fight with the lack of working room. How often would I need to use the extra length? Once would justify the mod! Thanks for the interest.
FEC3
Old 01-08-2008, 01:35 PM
fred cook's Avatar
Cool Wire resistance
The resistance of 12 ga wire is .00187 ohms per foot. Probably not enough to affect anything!
FEC3
Old 01-08-2008, 01:46 PM
Just a wild thought...but I would think you wouldn't want the wires to rest on the block because of the extreme heat and the possiblity of melting and shorting. Its been awhile since I poked around in there but don't the wires float above the case and under the shroud?
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 01-08-2008, 02:13 PM
I'll add one thing wrt alternator replacement and what NOT to do >
What not to do is use over-size washers on the air-direction part that affixes to the back of the fan assembly. A certain unnamed motor re-builder did on mine > and the oversized washers conatcted another metal part > completing a electrical circuit and damn near burned up my car..
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 01-08-2008, 06:39 PM
